Old 07-09-2014, 12:44 AM   #1
seano   seano is offline
oil level sensor?
Can anyone tell me if there is an oil level sensor on a 2004 flywing mx 150?
Is that what that is near the shift lever with 1 wire coming out of it?
What is that?
Old 07-09-2014, 07:50 AM   #2
katoranger's Avatar
I think that may be a neutral light sensor.
Old 07-09-2014, 02:31 PM   #3
Aha! Ok. So could it cause no spark?
Old 07-10-2014, 12:28 AM   #4
Not that I can imagine. Do you have power to the coil when you kick it over?
Old 07-10-2014, 03:39 AM   #5
Krasi_BG   Krasi_BG is offline
In theory it could. Some bikes "insist" on being in neutral in order to start. It could be working in conjunction with the side stand and/or clutch switch which are other usual "preventive measures".
Old 07-10-2014, 04:13 AM   #6
humanbeing's Avatar
That model is kick start ONLY ie. don't had such "luxury"
Old 07-10-2014, 10:39 AM   #7
katoranger's Avatar
I had a pitbike that required it to be in neutral to start.
Old 07-10-2014, 11:12 AM   #8
Me too, although there was no neutral sensor that I recall.
