06-22-2014, 05:44 PM | #1 |
new ride (I hope)
So I picked up a 1998 Polaris 250 2 stroke Trail Boss the other day (made a stop at W&G's house on the way home) ....get it home and put cables to it and it fires up and runs for about 30 seconds and dies.
today I emptied out the tank of old fuel changed the spark plug cleaned the carb very well added new mixed gas to the tank and nothing not even a burp and I did what I was supposed to to clean and check everything. only thing I can get off internet is that the rings may be seized or it needs a bore and new piston and rings :( any ideas guys?
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div> |
06-22-2014, 08:30 PM | #2 |
When you say "nothing not even a burp," does that mean that it won't even try to turn over now, or it won't fire?
06-22-2014, 09:17 PM | #3 | |
Upon reflection I do recall that any of the Chinese ones I have worked on had a big blue spark and this one does not so tomorrow I am going to go grab a new ngk racing wire and replace that next....one thing at a time
06-23-2014, 12:03 AM | #4 |
Congratulations on your new machine! If the worst thing you need to do is a piston rings, on a two-stroke machine like that, it should be quite cheap and fairly easy. I have heard many good things about that ATV, and I have seen a number for sale. Enjoy!
Happy to serve. |
06-23-2014, 07:14 PM | #5 |
Weld : I know this is a stupid question but .....do you have a compression tester.
06-24-2014, 02:49 AM | #6 |
So you have spark.... what about the carb... you said it run for 30 secs then
stoped... maybe it used the fuel in the float bowl... carb not getting fuel.. Reed valve... maybe the crank seals if it's been sitting... ( Added new MIXED gas to the tank !!!!!! ) But the main question thats on my mined is... "Has the oil pump been removed?" If not....Why are putting pre-mixed fuel in a oil injected motor ?.. Could be to oily and not sparking.... .
09 XT660R ... 06 TTR250 ... 80 Montesa H6 125 Enduro... 77 Montesa Cota 348 MRR "Malcom Rathnell Replica"... Current resto projects.. 81 Honda CT110... 80 Kawasaki KL250A1... 11 Husaburg TE125 enduro... "sold" along with another 31... Lifan 125 Pitbike.. "stolen" ... KIWI BIKER FORUM...... http://www.kiwibiker.co.nz/forums/content.php All the best offroad rides in NZ... http://www.remotemoto.com/ E-mail... xtpete1@gmail.com Last edited by pete; 06-24-2014 at 03:34 AM. |
06-24-2014, 09:31 AM | #7 | |
do not think that these had reeds from what I have read about them. the oil pump has been disconnected hence me draining out old mixed fuel and putting in new mixed fuel.
06-24-2014, 10:34 AM | #8 | |
06-24-2014, 10:35 AM | #9 |
Yes, but I might not have the specific adapter that is the same size as your plug. I can make an adapter out of your old plug, with a little time.
06-24-2014, 10:44 AM | #10 |
does not produce a fat blue spark
06-24-2014, 11:25 AM | #11 |
That's certainly not piston ring related. You could have stuck rings that are limiting compression, but the spark is something else. Do you have a test light? If so, you could check at the two primary wires of the coil to see if the coil is receiving power. If it is not, move backwards towards the stator. If it is, move forwards towards the coil, coil wire or boot.
06-24-2014, 11:35 AM | #12 |
I do have a test light but the coil is under the fuel tank in these ones so have to take the tank off to do the tests and might as well throw a new NGK racing wire in there wile I have it all apart. but will do as you have instructed weld.
07-03-2014, 07:59 PM | #13 |
ok so replaced the plug wire and definitely have a better spark...damn near had it fire today but now it is spitting fuel into the air box. removed the air box and had it almost start and then back fire a flame out the carb lol
letting battery charge over night and try again tomorrow
07-04-2014, 01:41 AM | #14 |
FYI, it would be a miracle for most two strokes to fire with no air cleaner installed.
I know you said you cleaned the carb well, but you're welcome to borrow my ultrasonic cleaner if you like.
07-04-2014, 01:47 AM | #15 | |
Covered the intake with 1 finger started and ran great |
