Old 07-20-2007, 10:12 AM   #1
In one day...
In one ride. I lost a countershaft cover bolt, had and engine bolt loosen, had an electrical malfuntion due to a crushed wire and had the spokes loosen...
I feel like I have reached a milestone! WOOT!
Old 07-20-2007, 11:26 AM   #2
gyjoe   gyjoe is offline
I guess you can call yourself a bona fide China Rider.
2006 Lifan LF200GY-5
Old 07-20-2007, 01:09 PM   #3
pumpkin   pumpkin is offline
i've had rides like that before you can get home to fix one problim something else happens. it'll get better well at least mine did
06 american lifan 200 gy-5
Old 07-20-2007, 07:20 PM   #4
Jim   Jim is offline
yeah you gotta watch the wires and cables, I went over mine with that wrap around corrogated plastic stuff for covering wires and put it around any cable or wire that was rubbing on anything.
Old 07-20-2007, 10:06 PM   #5
I've had rides like that. Lately, I've had rides where "NOTHING" fell off. 8O
Old 07-20-2007, 10:10 PM   #6
AZ200cc   AZ200cc is offline
Jims right, Wire loom can be a life saver for most wires..
Old 07-20-2007, 10:30 PM   #7
The wiring I have tied, tucked, taped, greased the connectors and heat shrunk most everything. What I missed was a connector routed inside the case. When I lost a bolt the case gapped and allowed the wire where it wasn't supposed to be and it got pinched.
I would actually like to make a new harness with better gauge wire and waterproof connectors. I may do it as I already have most of the stuff on hand. From what I have seen I think the electrical system is the weakest part of these bikes.
Old 07-21-2007, 12:20 AM   #8
Jim   Jim is offline
heh, everyone keeps pointing out the part they think is the weak spot I have been lucky to have no wiring issues, and I think I have a more complicated wiring system (alarm, remote start)
Old 07-21-2007, 06:23 PM   #9
Jim... maybe they accidently sold you a secret mil spec prototype...
Actually the wiring on my bike will serve it's intended purpose just fine, it just dosen't have much, if any overhead. Right now I need more lighting and just don't have the room for it.
Old 07-21-2007, 08:31 PM   #10
Jim   Jim is offline
mines canadian, we get an alarm and remote starter (I dont see the point in remote starting a bike, where you are supposed to have the fuel switched off).
I don't mind most of my lighting but am considering changing to an LED rear tailight, not an led bulb, but an actual light like off a truck.
Old 07-21-2007, 09:23 PM   #11
Hmmm, remote start, alarm..........does it also come with a backup beeper
beep...............beep...............beep.WATCH OUT LITTLE BILLY , that motorcycle is backing up.
Old 07-21-2007, 09:25 PM   #12
Jim   Jim is offline
it beeps when it signals... well.. it used too :twisted:
