Old 05-26-2014, 04:29 PM   #1
Killerbracing   Killerbracing is offline
Can't find neutral
When my bike is running, I can't find neutral. I have to turn it off and then find it. Is this common?
Old 05-27-2014, 01:16 AM   #2
Can be. Have you changed the oil lately? Have you lubricated and adjusted the clutch cable?
Old 05-27-2014, 08:26 AM   #3
I just changed the oil. The clutch cable is very smooth, not rough at all.
Old 05-27-2014, 10:56 AM   #4
That's two out of three. Have you adjusted the clutch cable?
Old 05-27-2014, 09:32 PM   #5
I have the barrel on the lever adjusted all the way out.
Old 05-28-2014, 12:47 AM   #6
Maybe try finding a balance between the adjusters on both ends of the cable. Try for between 1/8" and 1/4" of freeplay between the perch and the lever.
Old 05-28-2014, 08:30 AM   #7
zingshoen   zingshoen is offline
zingshoen's Avatar
i ve had this problem on the zong, and after adjusting the cable, i can find neutral with running motor, shifting down to first and then up a teeny weeny bit. it is working now, whereas before it was nearly impossible.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 05-28-2014, 01:43 PM   #8
Common. Synthetic helps tremendously.
Standard procedure is though....put it in first, let the clutch out slightly to put forward pressure on the bike. When you pull the clutch back in, click to neutral on the backlash.
