Old 07-19-2007, 06:28 PM   #1
Vaxian   Vaxian is offline
Hi-Bird self destructing
I have a 2006 Hi-Bird QH200GY
It is slowly self destructing as I ride it.
Every bolt, nut on it is coming loose and falling off.
So far I have lost the rear axle nut, the steering top nut, a turn signal cover, and a bunch of small screws holding on misc. parts.
It's also developed a nasty vibration.
On top of that I still have not found a reliable place to get parts!
Any suggestions, comments, offers of parts?
Old 07-19-2007, 08:43 PM   #2
Nasty vibe, check for loose/broken engine mount bolts... everything else... loc-tite.
There are several threads dealing with vibes. Use the search and you'll find everything from loose steering head nuts to engine bolts.
There's a guy on here parting out... I think a Viva... that should have a bunch of compatible parts. Look in the for sale forum.
Old 07-19-2007, 08:53 PM   #3
frostbite   frostbite is offline
Read all the FAQ's and the Tech Info section. See links at top of page.
Frostbite
"The beatings will continue until moral improves"
Old 07-19-2007, 09:39 PM   #4
ambassador   ambassador is offline
Vax,
Frostbite is right, you need to look through the FAQ's, Tech and follow the BIKE PREP THREAD, a $2 tube of loc-tite can save you alot of trouble...
These bikes have a certain degree of maintenance...
06 Lifan 200 GY-5
Old 07-19-2007, 10:19 PM   #5
liverchip   liverchip is offline
Send a message via MSN to liverchip
Yep check those motor mounts.
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 07-19-2007, 10:40 PM   #6
TheBrainII   TheBrainII is offline
I bet that rear axle nut coming off was a shocker. Did the real wheel wobble all over the place when it happened? Just curious, but how many miles have you put on it before it started falling apart?
BTW, do you know Lupi’s Pizza?
Bone stock 2007 Lifan GY-5
Old 07-20-2007, 10:36 AM   #7
Twice now I went back to the first page and read through absolutely everything. I spent more time reading than riding or fixing, then I did fixing, then I did the riding.
Old 07-20-2007, 11:32 AM   #8
gyjoe   gyjoe is offline
I haven't heard much about the large nuts such as the axle or steering top nut coming off on these bikes. Mine has a lock nut on the axle that stays put.
2006 Lifan LF200GY-5
Old 07-20-2007, 05:03 PM   #9
NewEnglandTrails   NewEnglandTrails is offline
Vax
Contact Member Tom from RPM, I believe he can get Hi-Bird parts.
Click on links to find his website, or drop him an email..
A certain amount of due dilligence and this forum should help stop the bike from falling apart from under you.
NET
2006 HIBIRD QH200-st atv, 2005 Kinroad 200GY-01, 2006 Roketa DB-05, 1980 Kawasaki KZ440 LTD
Old 07-20-2007, 10:54 PM   #10
ejcycles's Avatar
Vaxian
I have said it before..... Contact RPM here, PM him he can get parts for those bikes.
