Old 07-16-2007, 10:31 PM   #1
Guest
Posts: n/a
Loose Engine Bolts
790 miles and I have had to re-tighten two different engine bolts, even after using lock-tite during prep. My new mantainance schedule is change the oil every 500 and check all the bolts. Has anyone replaced engine bolts with a higher quality product?
Old 07-16-2007, 10:54 PM   #2
I have put grade 8's on my wifes and mine after having several engine mounting bolt failures between the two bikes.
Old 07-16-2007, 11:00 PM   #3
Jim   Jim is offline
I've broken my rear upper motor mount bolt 3 times, though after the original broke I never really had a proper bolt in there.
Old 07-16-2007, 11:11 PM   #4
I've noticed that a lot of the newer china bikes now have gotten rid of that long upper rear engine bolt and now have a mount closer to what I did on mine.
yeah that long 9" bolt in those loose fitting holes is just not gonna work.
