07-16-2007, 06:55 PM | #1 |
I have been Arrested. Well Spark Arrested.
Look what came via UPS today.
I wanted to be USFS legal and I found this on ebay. It is the Cobra Sparky spark arrester and this one was slated for a KX500. It was originally oval, but I easily made it round and it fit my gy2 exhaust perfectly. I use 2 sheet metal screws and the supplied clamp to secure. I am thinking of using some stainless steel wool for adding sound deadening. I like quiet. Allen
07-16-2007, 07:28 PM | #2 |
Do not use stainless steel wool, it will make your spark arrestor a spark generator.
Buy some standard issue muffler packing, and head to the hardware store for some 1/4in hardware cloth. Hardware cloth is a heavy gauge screen, used for everything from varmint-proofing to a base for stucco repairs. Cut the hardware cloth into a strip the proper width and about 1.25 times larger in diameter. Pack the SA to the desired level, then insert the hardware cloth like a circular spring. A little safety wire to secure the overlap would be cool. |
07-16-2007, 07:35 PM | #3 |
Ok. I was thinking that the stainless did not burn. There was an article on repacking mufflers. Maybe it was another type.
Thanks, Allen
07-16-2007, 07:37 PM | #4 |
I would also permanently attach a little chain from the SA to something very secure.
Sparkys have a way of escaping. I find them on the trails... |
07-16-2007, 08:46 PM | #5 |
I used a couple of screws, but I think some strapping and more screws will be added. It is a tight fit and I beat it on with a chunk of 4x4 treated lumber.
I will probably forget the added packing material. I remember where I saw the article on muffler repacking and it was a streetbike site. This may be only a temp fix. Just want to be legal if I am out in the woods. Allen
07-16-2007, 08:58 PM | #6 |
Would this work?
http://cgi.ebay.com/ebaymotors/10-x-...QQcmdZViewItem I am not sure if it would be even worth while. Allen
07-16-2007, 11:24 PM | #7 |
They sell the stuff at cycle shops, no biggie!
07-17-2007, 08:27 AM | #8 |
I will check the bike shop, I just like my internet shopping.
Allen
07-17-2007, 09:11 AM | #9 | |
07-17-2007, 10:00 AM | #10 |
I have burned regular steel wool before. I am going to use the muffler packing fiberglas stuff. No need to burn anything down.
I haven't ridden the bike yet with the sparky installed, but it did change the exhaust note some. Allen
