Old 07-09-2007, 08:01 PM   #1
shammash55   shammash55 is offline
Send a message via AIM to shammash55 Send a message via Yahoo to shammash55
rear break master cylinder
need some help. i changed fluid out on the rear break and now it dont work. bleed it and all and when i push the footlever down i can see the pad move maybe a mm, if i need a new cylender where can i get one or part list #.
it takes the insane to keep the world sane
Future 2015 csc rx3
Old 07-09-2007, 08:06 PM   #2
katoranger's Avatar
Let it sit for a while full of fluid. Sometimes gravity will help out and then you will be able to bleed the air out.
Othersie get a big syringe and a short piece of hose and suck the brake fluid through the bleeder valve.
Allen
Old 07-10-2007, 10:00 AM   #3
ridgerunner   ridgerunner is offline
instead of syringe
I've used a spray bottle to bleed brakes before. Take the sprayer thing out and attatch a vacuum line to it. Then loosen up the bleeder valve and attatch the hose. Pump away and you're done. Of course after tightening up the bleeder. I had an old Oldsmobile Delta 88 that I used this one and it worked great. Don't have to have someone in the car pumping like mad.
Old 07-10-2007, 12:46 PM   #4
it worked thanks.
Future 2015 csc rx3
