Old 08-28-2013, 08:51 AM   #1
racecoursepete   racecoursepete is offline
long case engine in short case frame? 139qmb 50cc
Will it work? My engine has blown but have found a cheap long case engine, just want to know if it will fit?
Old 08-28-2013, 09:24 AM   #2
Tvnacman   Tvnacman is offline
Send a message via Skype™ to Tvnacman
its going to take some work to make it work , you need to make sure the brackets line up . the spacing is the same. It could be more work than it is worth .
John
http://www.nycscooterparts.com/
For tech help call John 2125980016
Old 08-28-2013, 05:43 PM   #3
katoranger's Avatar
I think the most imported part would be the motor mounts. The rear shock can be adapted. Also make sure your rear wheel fits. Then you also may need longer brake linkages. This is if it fits under the bodywork.
Old 09-06-2013, 10:26 AM   #4
Thanks guys. It worked. The only difference between the 2 was one inch.
So the wheel was 1 inch further back.
Everything fitted fine.
Old 09-08-2013, 01:41 PM   #5
katoranger's Avatar
Sounds good. We don't get alot of scooter info.
