Old 08-11-2013, 02:18 AM   #1
overlander   overlander is offline
overlander's Avatar
correct tire pressure for skyteam v-raptor (retro) 250
In the owners manual it states
front: 250 kpa
rear: 220 kpa
but on the netrider.net.au forum I read:
One thing I have learned about these tyres is that you can't run them at what would be normal pressures. You need to have them at 18 PSI and no higher otherwise you will find it difficult to keep it on the road. Even the dealers didn't know this and the pressure in the manual is not correct. I went to a Suzuki Van Van forum and was able to find a lot of info about the bike from there.
18psi = 124 kpa
Any suggestions?
Old 08-11-2013, 11:13 AM   #2
What do the tires say?
Old 11-02-2013, 05:58 AM   #3
stellio78   stellio78 is offline
stellio78's Avatar
So Mark how are you going with your pressures set at 18 psi?
And what are the other V-Raptor owners running with?
Old 11-02-2013, 06:51 AM   #4
Krasi_BG   Krasi_BG is offline
I pump mine to about 2 bar, i.e. about 27 psi.
Old 11-03-2013, 03:07 AM   #5
stellio78's Avatar
I've set mine to the manual.
36 psi for the front and 32 psi for the rear, I'll see how it feels and if need be take a few psi out at a time.
skyteam, tire pressure, v-raptor 250
