henism 250 enduro
I have a hensim 250 enduro its my first bike. The guy that had it before me had been messing with the idel screw I got it to where sound good I think i don't really know but now it starts to cut of when it gets up to top speed any ideas?
Welcome!
When it cuts out at high speed, does it feel like it's running out of fuel? If so, change the fuel filter. If you don't have a replaceable filter, close the petcock and remove the petcock bowl for cleaning (if equipped with a bowl). Please show us pics of your new bike.
Those bikes were around for only a short period of time; I believe the predominant dealer was out of Ok City.
Welcome; we are glad you joined us.
I'm not sure but I don't think that it has a bowl.. now I have to get the clutch cable.fixed. do they have replacement parts? I can't figure out how.to get a pic on here
Click the advanced reply button and then you should see a paperclip icon. This will allow you to browse your computer for files and attach them.
could be a few carb related items. main jet needs to be cleaned, float and needle needs to be cleaned or float height set. if your really stuck for a clutch cable, motion pro makes custom cables for around $40 but you need to send them the old cable.
Mine had to big main jet when i had same problem.
half gas was okey and full gas it would die with no fire sound at all. no matter what start with carb cleaning and read nr on jet |
thank ill look in to that... I took off my clutch cable and its 44in can I just get another 44in one to work?
#10 |
Don't run them all out with out something to monitor temps. I thought mine was running good but know there is a hole in piston so....
#11 |
I got my clutch cable fix but now Im pretty sure my clutch is out so how hard is it to change the clutch and does anyone no a good site to get parts for hensim?
#12 |
What symptoms are you having specifically?
Happy to serve. |
#14 |
After I got my cable fix when I pulled in the clutch it didn't release after I let go so I started it and tryed putting 1st and it jump.forward and died tryed pushing it in at the engine but did the same.thing
#15 |
So, the clutch is stuck in the engaged position? Pulling the lever does not release the clutch? What happened to the first cable? Did it break or was it streched beyond its adjustment range?
Happy to serve. |
