Old 07-06-2013, 02:34 AM   #1
clrbrown   clrbrown is offline
Engine xchange help!
Stator xmoto is 8 pole different size. other 18 I believe..engine from street/dirt, so cant change that either.
Old 07-06-2013, 09:41 AM   #2
zingshoen   zingshoen is offline
zingshoen's Avatar
sounds like you need the diagram for the 166fmm viva :-) then u can compare and hook up.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 07-06-2013, 01:52 PM   #3
Welcome!
Can you post pics of both motors? I'm failing to understand why you can swap all of the electrical system from the Xmoto to the Viva.
Old 07-06-2013, 05:40 PM   #4
I just have the engine for the viva! No harness.
Old 07-07-2013, 12:53 AM   #5
Why can't you transplant the stator and flywheel from the Gio to the Viva?
Old 07-07-2013, 05:54 AM   #6
Welcome; we are glad you joined us.
Old 07-08-2013, 04:15 PM   #7
Stators bolt holes different! I did solve the problem though, I had to replace not only the valve head, but the cylinder head, new rings and valves, connected to old engine no problem, now have a smoker! Working on that now.
Old 07-08-2013, 09:15 PM   #8
I'm surprised that the bolt pattern was different. If you take it apart again, please take pics.
cdi, no spark, stator
