Old 06-20-2013, 06:06 PM   #1
tokarev   tokarev is offline
Viva 250 rear shock replacement
Looking for a replacement for the stock rear shock. It leaks out air as fast as you put it in. Zero dampening - Any suggestions ? Bought in 2007
Home of the SHTF 50 , SHF R50 and KEG12 shotguns
Old 06-21-2013, 01:56 AM   #2
Can you show us a pic? I think it was Waynec who came up with an epoxy repair.
Old 06-22-2013, 01:43 PM   #3
Rear Shock
Heres the shock
Old 06-23-2013, 01:29 AM   #4
Not the one I was thinking of. The one that was widely repaired on the forum was a piggyback type. Not sure what to recommend.
Old 06-23-2013, 01:31 AM   #5
Maybe I'm wrong, but didn't someone install an Yamaha YZF R6 shock in the hondoid bikes?
Old 06-23-2013, 01:58 AM   #6
That does sound familiar. Might be worth a search.
Old 06-23-2013, 07:03 PM   #7
the Shock
Finally removed the shock today - heres a couple pics. Really need to get this fixed - I need to ride!!!!
Old 06-24-2013, 01:59 AM   #8
Do these shocks appear as if they would fit?
https://www.google.com/search?q=yama...g&ved=0CC8Qsxg
https://www.google.com/search?q=yama...w=1407&bih=785
Old 06-24-2013, 10:55 PM   #9
the Shock
I think I solved my shock issue - today I disassembed the shock and played with the adjustment on the bottom. Seems to be working (the dampering part) seems to be holding air too. Have to reassemble and try it out. Now on to the front forks.
Thanks for the shock suggestions but there would be a major problem fitting the units with the side mounted reserve.
Old 06-25-2013, 03:00 AM   #10
Old 06-26-2013, 02:25 PM   #11
machinebike   machinebike is offline
ebay has a shock from showa and gio new off of a gio x31 250.
3 different prices, 1 for aprox 100, the other for 179 and one for 214.
The one for 214 has a visible valve up top and color is slightly different.
I could not decide which to buy, so I took my old one apart.
Old 06-26-2013, 10:49 PM   #12
the shock
I am leary of buying more of the same - I will try the old one now that I understand the adjustment.
Old 06-27-2013, 10:59 PM   #13
Is your shock the same as the ones on ebay...the showa and gio shock?
rear shock
