Old 06-17-2013, 11:35 PM   #1
Jibberwobble   Jibberwobble is offline
Jibberwobble's Avatar
Some ZS167FML questions for racing sidecar
Hi again
Well after a rather longer than expected interlude dealing with life's little obstacles it's time to have a look at the engine in my little sidecar (pushrod CG clone) and see if it will go any better with a bit of tickling!
We have now done three rounds of the British championships with my Zong powered outfit and we are looking quite competitive. There are 10 or 11 outfits in our grid and we run in about forth position usually which I'm pretty pleased with to be honest considering the norm is to get lapped every race for most of the first season.
The engine has run very well so far but is needing a little more power on the straights. The others are running various 80/85cctwo stroke moto-x engines, CB125 bottom ends with 160cc barrels or CRF150 four stroke Moto-x units. We have the least power out of all of them But for some reason I have come to like the Zong and would like to give it a fair crack of the whip before disregarding it as not good enough for the job. If I cant get it up to speed I will consider a different chinese engine before going Jap.
One point that is going to make engine development hard to measure is that the damn thing wont fit on any dyno I've come across yet! One way or the other the zonger needs to be putting out 20+ HP and ideally 22HP would be nice. I'm not sure this is ever going to happen though.
Currently I have a new exhaust going on soon and need to get onto checking the valve clearances before the next round in two weeks. Also got a big list of other mechanical issues to resolve.
So for some questions about these engines.......
I am running a 27mm mikuni, I want to try something bigger but what is too big? I'm thinking either a 30 or 32mm?? also a Carb that is not so tall as the Mikuni would be handy as it currently very in the way and stopping my laying down properly on the outfit. In addition I am considering a custom manifold to get the carb down lower but not sure how long the manifold can be before it starts to effect atomisation and power?
Is the clutch on these engine usually VERY stiff? It's definitely not the cable.
I need to have some gearing options, I am on 17-front and 24-rear (using 11" kart tyres (tires-american)). How big will I get away with on the front? Having an 18 and a 19 would be good but not sure they will fit. Cant find anything bigger than 17t for the Zong so is there a jap engine with the same shaft dimensions so I could buy a quality sprocket or two to fit?
Does anyone have any output figures from one these engines with all the restrictive rubbish removed?
Should I stick with standard Zong CDI's or is there a Honda etc variant that is the same or better?
Same as above for coil?
Anyone messed with valve timing?
Old 06-18-2013, 12:54 AM   #2
So many questions!
Before we begin, what is the actual displacement of your pushrod motor? Are you limited by displacement in your racing class?
This is the carb I like for 200 / 230 China motors: http://www.ebay.com/itm/Carburetor-C...4979d6&vxp=mtr I jet them with a 112 main and 27 slow at sea level for a 200, 115 / 30 for a 230.
This is the intake tube I have on my atv: http://www.ebay.com/itm/30MM-MANIFOL...fb51b8&vxp=mtr Not sure if it costs any power, but I doubt it. The air and fuel are happily sucked uphill by engine vacuum.
The clutch isn't normally that difficult; certainly no more than an average CG125. If you can't find a mechanical problem, perhaps this would help: http://www.ebay.ca/itm/Chrome-Hydrau...4c0632&vxp=mtr
You're using a 17 tooth countershaft sprocket and a 24 tooth rear sprocket? I can't believe that little motor can use such tall gearing. I figured that 40 teeth would be the outer limit for a rear sprocket.
I would certainly try a racing CDI, or even a programmable unit.
I've never messed with timing. I would focus on smoothing the intake port and polishing the exhaust port first.
Old 06-18-2013, 02:10 AM   #3
Thank you Weld.....
Just popped in and gotta rush off again so will be back later to reply properly but in answer to the gearing thing, I am running an 11" kart rear tyre instead of a big bike wheel and this will bring the gearing right down to something nearer the norm. We are pulling about 60MPH on the long straights at tracks that are about 1.2km all the way round.
It's a 200 which is the displacement limit for a 4 stroke in the regs. 85cc for a two stroke.
Old 06-18-2013, 11:05 AM   #4
katoranger's Avatar
I don't know if anything bigger than a 17t will fit. You may have to drop a tooth on the rear.
Old 06-18-2013, 01:24 PM   #5
The trouble I'm having with gearing is that I'd like to have options to go both higher and lower than my current setup. I have a tired 24t on the back and feel that a 26 would be nearer the mark for most tracks.
Because there is not much size difference between the front and rear one or two teeth on the back makes quite a big difference. Going up on the front and back will give me ratios that lay in between just going up in 2t increments on the back alone.
In addition the 24 I have on the back seems to be very rare and all I can find to fit a 30mm kart axle is 26/28/30 etc nothing smaller, so a bigger front would bail me out a bit.
Hopefully tomorrow or thursday I will get the chance to pull the cover off and have a closer look to see how much room there is.
So is there a common mass produced front sprocket fitment that will go on my zonger? Seen some Yam ones that look the same but havent laid my hands on dimensions yet
Old 06-18-2013, 10:11 PM   #6
I believe this is the JT sprocket that fits your countershaft: http://www.jtsprockets.com/catalogue/sprocket/JTF259 It only goes to 17.
Old 06-19-2013, 01:10 AM   #7
So many questions!
This carb looks good, does it bolt straight to the engine or are the holes a different pitch? Just a thought because if it were sitting that close to the engine it may not get in the way too much.
Funny enough I've been watching that one for a while wondering if it's the answer to some of my problems, just going off to have a look through your threads for a picture of it fitted (assuming there will be one somewhere). Shipping to uk is a bit scary though.
Well when I compare my clutch lever resistance with other peoples I would say mine was around ten times heavier! I can pull most clutches in with a couple of fingers but with mine I need a good grip and most of my strength. Oddly I dont notice too much when we're out on track most likely due to Adrenalin. Havent had a chance to research how it all goes together yet but will have a look into it and go down the hydraulic route if all else fails. Thanks for the link
Indeed my tiny 11" tyre on 5" rim brings the gearing back down.
Will have a look into this and try and find something. I'm a bit lost with the CDI's to be honest, is a 125 CDI different from a 200 and if so what does it do differently? I need a spare so will get scouting, I think it's a bit more of a struggle to find this chinese stuff in the uk and the unknown import duties bother me a bit when ordering offshore.
Ok will have a peek into the inlet/outlet and see how they can be improved, this sort of thing is up my street. I can get 11.5hp from a 40cc w/c 2stroke with the aid of my trusty dremel and it's friends! Time consuming but satisfying.
Thanks, done a bit of looking now and have found some chinky ones (18t) very cheap that I think will fit the shaft so I will go for it and see if it fits in there, I'm sure it will be fine for experimenting.
http://www.fiddyparts.co.uk/index.ph...art&Itemid=107
http://www.ebay.co.uk/itm/PITBIKE-FR...item41732a3e3b
http://www.ebay.co.uk/itm/18-TOOTH-4...item41741f3a7e
Old 06-19-2013, 01:38 AM   #8
The 30mm Mikuni bolts to an intake tube (of whichever style). I don't think you'd be successful without at least an insulator. This intake is free to ship to me, and I could always post it to you, if you wish. perhaps that would save a bit. http://www.ebay.com/itm/30MM-MANIFOL...fb51b8&vxp=mtr
Bogieboy has experience with hydraulic clutches, so I recommend that you seek him out.
Different CDI's will have not only dissimilar amounts of advance, but also different rates. Humanbeing is our resident expert.
That's cool that you found 18 tooth sprockets. I wonder if you'll have clearance problems.
Old 06-25-2013, 04:19 PM   #9
Whoops been all tied up for a few days pulling my old car to bits to sell as much as pos before scrapping it, it's funding the sidecar upgrades and spares.
Also been busy finding the right parts for the outfit and trying to get em all to arrive before this weekends race meeting. I've got so much to do before it's ready I'm pullig my hair out!
I now have the 18t front sprocket and it looks like it will work with a little relief to the cover.
I'm out of T-break now but will be back later with some pictures
Old 06-26-2013, 12:50 PM   #10
Do you mean the sprocket cover? I'd just remove it completely; that's how we do it on dirt bikes.
Old 06-26-2013, 11:46 PM   #11
You know what, thats a bloody good idea!
As it goes I will have to stick with it for now for safety reasons, My fully enclosing bodywork is not built yet and I have some very temporary bits of chopped up second hand fibreglass on there. Eventually the seat unit will go all the way up and over the engine enclosing the chain all the way from front to back, right now it's exposed at the front which is a bit iffy really although my legs have survived a couple of chain breaks and a derailment.
To get an idea of the riding position kneel on the floor with your knees 18inches apart and your toes pointing at the floor and your butt sat 6inches above your heels. The chain passes about 1 1/2 inches below your knackers and 3 inches inside you left thigh. In an accident it would be very easy for a flailing limb to say a little hello to the front sprocket and have a little go on the roundabout!
I've done a quick mod to get me by for now so we'll see how it goes this w/e.
Cant find a good photo of the seating position and chain run just now but you sort of get the idea from this
So with the 17t sprocket roughly placed in the cover you can see the clearance situation
And the mark on the inside of the cover, I think this happened on a joining link break. We now have a new chain and will be rivetting it. There were various other issues causing chain troubles and most of the worn out and poorly set up parts have been replaced with new now. Axle, bearings, chain, front and rear sprockets, break disc and carrier all replaced.
Chop chop!
Very thin peice of Carbon sheet is now giving me another few mm of clearance.
And with the 18t in place it all gets a bit tight but I think just about doable.
Old 06-26-2013, 11:54 PM   #12
The clutch and CDi will have to wait for the minute, just need to get through this w/e and once the dust has settled I'll attack these issues and search out these two guys for some of their wisdome. Thanks for pointing me in the right direction.
Will also get back onto the carb and manifold, I need to have the carb finalised before I can build the seat unit up.
Old 06-27-2013, 01:42 AM   #13
You're a tortured artist, aren't you? That sprocket cover looks as if it was cut on a milling machine. Those tubing bends are beautiful; do you have a mandrel bender?
Old 07-03-2013, 12:41 AM   #14
Thanks for your kind comments but it actually looks quite grewsome in the flesh! I just used a hack saw and barrel grinder to do the casing. The bends are done with a Hilmor pipe bender similar to the one pictured below, for the heavy duty hydraulic tubing it can be a family effort with the my good lady and kids hanging off the frame whilst I hang off the end of my trolley jack handle like a gibbon in a tree.
It all got very busy at the end of last week getting ready for the race meeting and the last of the parts I ordered arrived just in time. We had a good laugh on track and once again battered the bodywork bouncing off our sparing partners, really need to get some video. Loads of teething troubles with new parts and set up issues but the 18t front pinion and gear ratio change worked very well with no problems.
Before the meeting I changed the exhaust from a stock 400cc CBR to a 600cc Micron performance exhaust with a 35mm outlet. I did this because the old exhaust was getting quite broken and the new one was given to me. Being much less restrictive I suspected a jetting change would be needed and was indeed not wrong. On our first out lap it felt a bit gutless and got very hot, the plug had a tinge of white around the shoulder of the electrode so I went on the hunt for a bigger jet. We had a 120 in there (Mikuni VM27) and all anyone could come up with was a 150! it was worth a go as the sun was beating down and everything was hot, and my Zonger was gonna cook on that 120. with the 150 the engine felt less strangled but as you would imagine it got half way up the rev range and started to splutter and was avoided by a short shift in every gear. By the end of each session it had surprisingly almost cleared though. Eventually found a 130 jet which I think is still a little lean but it got us through and we finished 5th, 4th and 3rd respectively in our three races despite not being able to find 5th gear half the time.
Back soon to address some of the issues.........
Old 07-03-2013, 10:32 AM   #15
I have a numbered drill bit set that I've used for quick jet size increases. Sometimes you're in a situation where you simply can't get the jet you need, so a drill bit is the next best option.
Please show us pics of the new exhaust.
pushrod, racing, sidecar, zong, zongshen
