Oil plug almost stripped off
The oil plug has never been a nice feature on my DB-07. It seems like the bolt head of it is tapered, and with the shiny finish on it it's almost impossible to keep a wrench from slipping off of it.
Today is much worse though. I couldn't get it to budge and it even mawed off one of the edges of the bolt head. Now I have no idea how to change the oil and it's at 400 miles on this change. Any suggestions about how I might get it off and how I can get another plug? |
Do you clean your oil filter? I don't use the bottom plug anymore, I undo the large side bolt where the mesh screen is that collects the metal grindy bits from your oil. That way I don't have to undo the skid plate every time I change the oil. I don't know if this is what the pro's do? Just what I do. Can you find a replacement bolt? :wink:
That's exactly the one I'm talking about. I've never used the smaller bolt on the bottom. Maybe it's time?
Use a socket?
Isn't your oil screen cover bolt thing plastic? I am sure mines plastic... hmmm
Jim, my plug is metal (china pot)I believe. Talking the one on the side that holds the filter screen.
I use a large socket, but I can't remember the size. Getting due for a change too. I think this time will be real 4-stroke m/c valvoline. Allen
I think it is a 22 or 23mm.
Vince |
It is large like that. I have a set of metric impact sockets in the correct size that fit. Makes it much easier to remove and install. Check at a harbor freight or northen tool for one. Otherwise Home Depot may have one too.
Allen
Oh ok, maybe its just funny metal... or maybe I am thinking of the dipstick...
#10 |
A good 6-point socket almost nevers grinds the biting surface off a bolt/nut.
Those 12-point sockets will strip a bolt/nut very easily. Even a good 6-point can take apart what a 12-point has ground up sometimes. |
#11 |
23 mm on mine. Odd socket size, so it's expensive. 23mm wrench at home depot 13$
#12 |
The large impact sockets are all 6 point. It must be the 23mm then that fits.
I think I paid $30 for the set of 12 sockets. They were made in China, but I only use them occasionally. Jim, I think the dipstick is plastic. The filter plug is a cheap metal. Allen
#13 |
I guess I'll have to invest in a socket set. This wrench isn't going to cut it. I hope that the bolt isn't too damaged.
However, I did use the little plug to change the oil so I'm okay for now. |
#14 |
A 23mm won't come in most socket sets. You will probably have to buy it separately or buy a set of large 1/2" drive sockets like mine. I bought them at a place the sells china tools and liquidation type stuff. Never know what they will have. Home Depot probably has the individual socket or a set with one in it. I would buy a whole set unless you have a use for all the other large size one.
Allen
#15 | |
When I changed my oil last time, I didnt notice but the o-ring behind the plug came out with the oil and I put it all back together and filled it up, then found the o-ring in the bottom of the oil... Oops :oops: ... just laid the bike over (brother and dad held it just off the ground) and undid the plug and replaced the oring and put it back, all was well ![]() |
