11-24-2012, 06:04 PM | #1 |
aftermarket headlights install
got a set of 9 led daytime driving lights from china to replace the stock ones on the 150 utility as they each draw 18w each and drain the battery but the new led's only 9w each so this should take the strain off.
here is the old set up in the body you can see that the new ones are a tad smaller than the old lenses brilliant idea!! :idea: dig out dremel and bit and go to town on lenses. carve out just enough to insert the new light into the old lense both new lights set up and ready for the next step.... allot of hot glue for plastic. after the hot glue has set and has cooled next step it to use gorilla glue to re-attach the lens to the base of the original pot (which is also the mounting bracket) both done now and left to set up over night then install tomorrow we used my 18v drill battery last night and hooked up both lights to it and turned out the lights ...wow are these ever bright ...can't wait to try them out tomorrow night.
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div> |
11-24-2012, 09:52 PM | #2 |
Excellent engineering. 8)
I'm surprised they draw even 9 watts each. I thought LED's were close to nothing... The 18 volts won't hurt them if they're made for 12?
Happy to serve. |
11-25-2012, 01:18 AM | #3 |
bad description on my part lol
they will use half the voltage the stock lights used edit: I do not believe that the test using the 18 v battery would hurt them.
11-25-2012, 12:21 PM | #4 |
Clever install. I still wouldn't turn them on until necessary, but they'll certainly draw less than the incandescent bulbs. Are you gonna use the stock switch and wiring?
11-25-2012, 12:32 PM | #5 | |
11-28-2012, 09:46 PM | #6 |
got the lights installed today and just for the parade we are going to be in will use the stock wiring and switch
we have light gentlemen!!! still have to wire them in properly but that is an easy task
11-29-2012, 11:54 AM | #7 |
Looks great!
Funny they are the only clean part of your ATV!
Happy to serve. |
11-29-2012, 12:08 PM | #8 | |
yes i had a chuckle about that too we will be cleaning the atv's for the parade :P
12-02-2012, 09:06 PM | #9 |
just not nice weather out there today so made an exhaust port for testing
needed to run the atv in order to check the draw on the battery wile running markers, headlights and brake light ....check this out this is at idle with all the lights on and brakes applied
12-03-2012, 08:54 AM | #10 |
Those look great. Looks like the charging system is happy too.
I need some rectangular lights for my new tractor.
12-03-2012, 09:59 PM | #11 |
I like your exhaust vent.
12-04-2012, 09:50 AM | #12 | |
12-23-2012, 04:09 AM | #13 | |
Re: aftermarket headlights install
12-23-2012, 04:33 PM | #14 |
I saw Midlife and his wife at the Mission Parade and I can tell you those lights are bright.
Plus his quad started, cough can't say that for the Grizz at that time. Its running great now but had to do some carb work. Midlife amazes me at all he can do and how well he does it all. HE IS A TRUE MAN'S MAN!!! My hat is off to you Midlife!
TCCK: The Coca-Cola Kid......... Hide your pepsi or I take your soul !! |
