Old 06-09-2007, 07:55 PM   #1
shammash55   shammash55 is offline
Send a message via AIM to shammash55 Send a message via Yahoo to shammash55
mistery oil leak help.
i have a oil leak on my motor. it looks like its either on the front left of the jug where it bolts to the engine but also a lil drop of oil appears on the button thats on the side of the jug on i guess a oil channel in the jug.i cant figure where its comming from.
it takes the insane to keep the world sane
Future 2015 csc rx3
Old 06-09-2007, 08:27 PM   #2
FMYStreetRacer   FMYStreetRacer is offline
pics?
also try cleaning it off and buying a oil dye detection kit. they are a bit pricey but if you can find a guy that works at a local shop that will test it on the side you'll be in good shape.
Roketa DB-07a
HID Headlight
Old 06-09-2007, 11:18 PM   #3
Guest
Posts: n/a
I had a mystery leak and found it to be a o ring sealing a sensor located under the front sprocket. O ring was molded poorly. If an o ring is near your leak check it.
Old 06-10-2007, 12:18 PM   #4
buymore   buymore is offline
I'm getting a little oil leaking out around my shift lever on my Roketa DB-05. Just a drop once in awhile, nothing major yet.
Old 06-10-2007, 04:23 PM   #5
jkomp316   jkomp316 is offline
Send a message via AIM to jkomp316
I think the Hawaii VIVA guy had his engine do the same? Leaked around the jug after 3000mi or so? Sound right?
Old 06-10-2007, 08:25 PM   #6
msRandi   msRandi is offline
Send a message via AIM to msRandi
On ours the leak was at the right rear at the base gasket. But the motor I just put back together has a new leak at the left front of the base gasket, and yes there is a O ring there. I should not of tryed to reuse the O ring. it's EZre and faster to get a new motor than a full set of gaskets.
Love from the Arizona High Desert
Old 06-10-2007, 09:38 PM   #7
it sounds right on the akonababy viva. i was gonna see if i needed to put a new oring on the button but i couldnt get it off. i guess it takes a special tool for it, the button on the side of the jug that looks like a big flathead screwdriver could take it off.
Future 2015 csc rx3
Old 06-11-2007, 05:14 AM   #8
Oh god dont pull that part it holds the cam rockers inside the motor!!!!!!!!!!!
