Old 08-14-2012, 05:00 PM   #1
katoranger's Avatar
Look what has made it to the USA.
http://cgi.ebay.com/ebaymotors/250cc...item5d34aa7e35
Old 08-14-2012, 05:10 PM   #2
Very cool. 8)
3 things I don't understand.
The copy says automatic? I thought these were manual 5 speeds. Also why not street legal, and finally, How can it have a BIN price of only $1,000? Almost sounds fishy...
If that price was real it would be a steal if a guy had a use for it. :P
Old 08-14-2012, 05:11 PM   #3
Copy says 250, side of bike says 200... Some usual discrepencies...
Old 08-14-2012, 07:28 PM   #4
katoranger's Avatar
My guess is that this one is a dealer sample and probably the only one.
Old 08-15-2012, 02:46 AM   #5
I'm sure you could get a license plate for that trike in Idaho. Even if it's only a 200cc engine, I think that trike is a steal at that price!
Old 08-15-2012, 11:24 AM   #6
katoranger's Avatar
I noticed it has a shaft drive.
Old 08-15-2012, 11:30 AM   #7
Shaft drive makes perfect sense. I was thinking that an old ATC motor with shaft drive would be a good donor for a home-brewed version.
Old 08-15-2012, 12:19 PM   #8
katoranger's Avatar
I was looking at the countershaft area and it appears that they adapted a gearbox to a standard chain drive engine.
This has me thinking. Old shaft drive bike and a rear axle from a small rear drive car.
Old 08-15-2012, 03:02 PM   #9
Old shaft drive bike = no reverse.
A current 200cc atv engine would do the trick, except for the chain drive. A China atv reverse gear installed in an old Honda Big Red atc has potential.
Old 08-15-2012, 03:14 PM   #10
Still available. I think it's a steal for someone who can use it. :P
Old 08-15-2012, 04:00 PM   #11
katoranger's Avatar
Good point. That would make backing a load difficult.
Old 08-16-2012, 02:04 AM   #12
I wonder if the gearbox is available as a spare part?
Old 08-16-2012, 09:42 AM   #13
katoranger's Avatar
Probably not in the US.
Old 08-25-2012, 09:58 PM   #14
I'm thinking that the lever should say slow and slower with the weight that poor little engine has to haul around.
...and don't put any gas in it as the gas line isn't attached.
Old 08-25-2012, 10:06 PM   #15
The sixth picture shows a lever that might be for forward/reverse. It's located above what looks like a filler for gear lube.
