Old 06-05-2007, 01:33 PM   #1
mdsuave13   mdsuave13 is offline
Send a message via AIM to mdsuave13 Send a message via Yahoo to mdsuave13
Front suspension "sticky"?
I have noticed that my front suspension feels "sticky" it doesnt smoothly adjust up and down. I weigh 165lbs and it just stays uncompressed until i really brake hard, then it will go down, but with small adjustments, it has a notchy, sticky feel to it.
Has anyone experienced this or fixed this? I am wondering if it needs the fork oil changed or if it is the overall crapiness of the front springs....
anyone want to field this one?
My name is Justin, my friends call me Stix.
2008 Kawasaki KLR650 Candy Lime Green
______________________________
I am the official China bike registration Guru For the State of Maryland..... HA.
Old 06-05-2007, 01:45 PM   #2
jkomp316   jkomp316 is offline
Send a message via AIM to jkomp316
Mine is like that to an extent. It wont compress at all when i sit on it. If a give it a nudge with the front brake it goes down though. I havent looked into it but I guess the fork oil is like vegitable oil or something You might want to change it.
Old 06-05-2007, 01:49 PM   #3
red2003   red2003 is offline
I weigh 210 and my Roketa with USD forks acts like that too. I would prefer them to be softer sprung. It's not like we can sail these things off jumps anyway. I think a fork oil change WOULD help, but that's a fairly big job with inverted forks. Gotta pull the whole front of the bike apart. I think that'll be my next project. I will pull them apart and change out the stock fluid for a lite weight synthetic fork oil.
Old 06-05-2007, 01:57 PM   #4
Maybe the Chinese found an easy way to get rid of all thier leftover fry oil? Start manufacturing "USD" forks!
Old 06-05-2007, 01:57 PM   #5
molypod   molypod is offline
By changing my fork oil and by cleaning my seals I have noticable difference in the smoothness..
Here's the thread. Forks
Old 06-05-2007, 02:03 PM   #6
thanks molypod, that is VERY helpful...
that is the other sweet thing about these bikes, i wouldnt feel so bad if i totally screwed something up because its a inexpensive purchase as compared to a high end jap enduro. I can learn how to do more extensive repairs on this for when i buy a much bigger bike down the road.
Old 06-05-2007, 02:09 PM   #7
Ditto.
Old 06-05-2007, 02:43 PM   #8
IMHO i'm not sure i would trust full synthetic fork oil in the upsideown forks. our chinese fork seals are not the best.
Old 06-05-2007, 03:03 PM   #9
Yeah, a lot of people are under the impression that synthetic oil "leaks" by more then conventional. It has never been my experiance, or any one else I know for that matter, that I or they have ever seen this or heard of a situation where changing to synthetic oil caused a leak that wasn't already present to begin with. Synthetic oil molecules are not necessarily any smaller then dino oil, they are just more uniform in size since they are man made.
Old 06-05-2007, 05:38 PM   #10
blimpman   blimpman is offline
Make sure that the torque on the triple clamp bolts iare correct. Locktite of course. You can crank down and pinch the tubes too much.
The destination is merely a by-product of the journey.
'06 KLR650 '06 XT225 '92 XT225 Serow
( MBD.... Multiple Bike Disease...)
Old 06-05-2007, 07:36 PM   #11
I put about 4oz of Trans Fluid in my USD forks and they seem to be working fine. I did not remove my forks. Only the top screw cap.
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
Old 06-05-2007, 10:00 PM   #12
madmaximum   madmaximum is offline
Send a message via AIM to madmaximum Send a message via Yahoo to madmaximum
Did you add the tranny fluid because your forks were "sticky" too? I've noticed that mine will compress when stopping, & "pop" back up when I take off.
2005 RSX-200E
2004 Suzuki Eiger
1999 Arctic Cat 250
1977 Kawasaki KH400, aka Green Ripper
Old 06-05-2007, 10:54 PM   #13
liverchip   liverchip is offline
Send a message via MSN to liverchip
Mine are actually a bit soft. I definitely use the full travel during my rides. I am 215 It really needs stiffer springs IMO, I know I can preload the existing springs with washers, but that takes away travel and only hides the issue. What is the consensus on fork oil type. I'm thinking a heavier weight oil to increase dampening and help out.
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 06-05-2007, 10:55 PM   #14
stixx3969   stixx3969 is offline
Mine does it to some extent but I'm used to it. May do new oil some day.
Old 06-06-2007, 01:59 AM   #15
I dont think changing to a full synthetic fork oil will "cause" it to leak. But I do think it will leak faster if there ever is one. I don't have much faith in the seals :wink:
