06-07-2012, 12:06 AM | #1 |
2004 diamo avalanche 250cc atv help!!!
I just bought this atv. Its a 250cc shaft driven with a "slip clutch" no lever on handlebars. Problem is... it goes into gear but doesn't move. What could it be and where can I get parts?[/list]
06-07-2012, 01:44 AM | #2 |
Welcome! We are glad you joined us.
I moved your post to our ATV Forum, so your questions could get more exposure, and more replies. Spud
06-07-2012, 05:52 PM | #3 |
Thank you!
06-07-2012, 05:59 PM | #4 |
I don't know what you mean by a 'slip clutch'.
Happy to serve. |
06-07-2012, 10:59 PM | #5 |
I guess it wld be semi auto. Has reverse then 4 or 5 up. No clutch lever. Like old honda 3 wheeler I used to have.
06-08-2012, 01:05 AM | #6 |
more than likely it has some sort of WET CLUTCH system internal in the motor and the wet clutch is too worn.
TCCK: The Coca-Cola Kid......... Hide your pepsi or I take your soul !! |
06-08-2012, 07:41 AM | #7 |
Did it work when you bought it or did you buy it the way it is?
06-08-2012, 01:03 PM | #8 |
I bought it this way.
06-08-2012, 08:26 PM | #9 |
Does it make any weird noises when you put it in gear? If it's making a grinding or whirring sound the shaft drive may be damaged. Otherwise I'm guessing that it's the clutch or clutch adjustment. Most of the auto's have a provision for adjusting the clutch. I'm guessing you must have gotten a pretty smoking deal on it if it didn't move when you bought it!
06-08-2012, 10:27 PM | #10 |
It makes no noise. U can feel it click into gear through the shifter but it gets no power to the shaft. U knw how its got the small cable going from by recoil to the transmission... that lever its hooked to it held forward by a piece of wire to keep it from pivotingto the rear of machine. The rest of the quad is mint... n yes got a smoking deal, can't wait to get it moving. The kid I got it from thought it was rear end issue but it rolls just fine just seems like its constantly in neutral.
06-09-2012, 10:52 AM | #11 |
Please show us a pic of the lever that is held by a piece of wire.
06-09-2012, 07:44 PM | #12 |
Ok so it turns out the lever held by wire is reverse but the actual lever is missing but when I move that the rev light on dash works as normal and feels like its going into gear but the neutral light is on and it just revs....
06-09-2012, 10:38 PM | #13 |
Ok so I tore into the quad today. Found it it definitly something in rear end. I pulled rear end out today. Was wondering what to expect when I split it tomorrow. I can hear something slipping inside. Can hold center shaft still and sping tires....
06-09-2012, 10:57 PM | #14 | |
06-10-2012, 11:57 AM | #15 |
Ok will do. Gonna split it today and I'll take some pics. I can't wait to ride this atv. Once I get rear end issue fixed all I have to do it get the brakes working n I'll be ready to ride
