Old 05-25-2012, 08:16 AM   #1
Wool-Z   Wool-Z is offline
Possible Zongshen CDI options ?
Seems my CDI is going out. Suggestions on where to get? Other than Zongshen America or Tabao? Not so sure bout that Tabao website. And I was just looking for other options. What TW200 CDI works? Anyone every try a "performance" CDI, did it work?
Old 05-25-2012, 02:20 PM   #2
Talked to Zongshen $48.95 for one CDI plus shipping. Up a bit from the $25.00 they were. 8O
Old 05-25-2012, 04:03 PM   #3
Somebody tried a Yamaha CDI unit in his Zong. If I remember correctly, he said the Yamaha, CDI unit worked, but he had to rewire his bike to make the kill switch work. You can search this forum and find the thread.
I am sorry to hear the Zongshen CDI units have increased in price so much; however, they are still less than half the price of a Yamaha CDI unit. :roll:
I might be wrong, but I can't remember anyone experimenting with a "performance" CDI unit in his Zong.
Old 05-25-2012, 07:28 PM   #4
obso   obso is offline
If anyone wants to donate me one (they can't be that expensive can they?) I'll document how to make it work. I'm a bored EE.
Mine was just replaced ~100mi ago but if it ever dies again this is what I'm going to try. The first one I googled (the zongs are ac, rite?) even said it used a variable resistor to change the timing curve! That would be awesome since there is presently no way that I've found to change (advance) the stock timing a little.
Old 05-26-2012, 12:27 AM   #5
The Zongshen 200GY-2 does employ an AC-CDI unit. Of course, you would need to make a wiring adapter to connect the adjustable CDI unit in the link you posted.
If you're bored, you could perform a great service to Zong owners by contributing to the following thread, Obso!
http://chinariders.net/modules.php?n...wtopic&t=11397
Although it is not adjustable, the Lifan CDI unit for the 150cc engines is inexpensive, and readily available from a wide variety of vendors. I'm sure Zong owners would be grateful if you could figure out how to make the Lifan CDI unit work for our Zongs!
Old 05-26-2012, 03:30 AM   #6
Wild_Alaskan's Avatar
also the cdi pics spud posted have the same plugs as the 400ex sport quad if you are looking to convert to that style. the 400ex cdi was compatible with my lifans 200cc engine
Old 05-26-2012, 03:42 AM   #7
zingshoen   zingshoen is offline
zingshoen's Avatar
obso, let me know how much the best project cdi is gonna cost?
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 05-26-2012, 11:07 PM   #8
humanbeing's Avatar
the "Programmable" ?
http://item.taobao.com/item.htm?id=9465817427 | The success story : http://www.motorfans.com.cn/bbs/t_16895002.htm
I guess that "adjustable" for Honda clone won't works
ZS / Yammie are longer which some ancient "programmable" can't set probably :oops:
http://www.motoefi.com/bbs1/read.php?tid=1791
Difference btw the ZS AC / DC CDI.
Old 05-27-2012, 03:48 AM   #9
zingshoen's Avatar
humanbeing
thank you but
maybe i not understand:
two pictures are same?
Old 05-27-2012, 05:04 AM   #10
humanbeing's Avatar
Difference is pin 6, 7
Upper
pin 7 : Working = grounded / Not connected = Off
lower
pin 6: DC 8-12v that are regulated
pin 7 : NIL
(WYSIWYG ) Input chinese http://www.nciku.com/ Just think each character as a different picture
Old 05-27-2012, 05:15 AM   #11
zingshoen's Avatar
ok, makes sense now, thank you
Old 06-01-2012, 10:32 AM   #12
I was told CDI for Yamaha TW200 is appx $300.00 from Yamaha shop. So I figured $60 shipped from Zongshen is still a good deal.
Old 06-01-2012, 12:20 PM   #13
The photographs of the CDI unit I posted in this thread do not have connectors compatible with the Zongshen wiring harness. Please note, I said one would need to make a wiring adapter if he wished to experiment with this aftermarket CDI unit. The connectors of the Honda, 400EX CDI unit are also not compatible with the Zongshen wiring harness.
Old 06-01-2012, 12:39 PM   #14
According to one internet parts seller, the Yamaha, TW200 CDI unit retails for $193.92. The best internet price I have found for the TW200, CDI unit is $142.91, plus shipping. 8O
http://www.cyclepartswarehouse.com/f...009&fveh=28571
Also, if you install a TW200 CDI unit, the Zongshen engine will not shut off unless you modify the Zongshen wiring. :roll: If you wish to learn more, you might enjoy reading the following thread.
http://chinariders.net/modules.php?n...wtopic&t=13099
