Old 05-30-2007, 10:22 PM   #1
msRandi   msRandi is offline
Send a message via AIM to msRandi
bad vibeacions
on the newest motor. the OHC lifan I put in Rachel's Viva. when the motor is under a load there is growl like a bad bearing, I have pulled the rear wheel off and checked the wheel bearings, checked chain and sprockets, wheel hub and pulled the cluch apart. I can't find the source. any better ideas?
Love from the Arizona High Desert
Old 05-30-2007, 10:45 PM   #2
ob1   ob1 is offline
Double check the chain and sprockets. Sounds like a stretched chain.
Old 05-31-2007, 07:58 AM   #3
red2003   red2003 is offline
That would be my guess too.
Old 05-31-2007, 12:33 PM   #4
frostbite   frostbite is offline
It sounds like the same thing I encountered. I swapped out the chain/sprockets - no change. Turns out it was the transmission. New engine (replaced under warrany) cured it. Under idle no vibration whatsoever, however, once warmed up under load it was vibration city. It got so bad I blew 1 headlight, 1 tailight, 1 dash light.
Frostbite
"The beatings will continue until moral improves"
Old 06-02-2007, 09:19 PM   #5
katoranger's Avatar
Mine vibrates and has a growl when I let off the gas. Vibration have gotton worse. Only at 205km. I have blow the headlight already.
Going to call AL and ask them.
Allen
Old 06-02-2007, 11:36 PM   #6
Akonababe   Akonababe is offline
Frostbite, you were right the transmission is blown. Spoke with longevity and waiting on his reply for the replacement. Only 2 weeks and the transmission gone. Sounds like they are going to honor the warranty but we shall see.
Ride hard and have FUN!!!!
Old 06-03-2007, 08:34 AM   #7
Holy smokes. That's horrible news. Especially if others are having issues. Frosty, did you get to take the tranny apart to diagnos the problem or did it get shipped back?? This seems like a Lifan problem so far. I'd be curious to know what's up in there and a little nervous about losing the tranny at highway speeds. OB1, what do you think. I have no experience with a motorcycle tranny.
Old 06-03-2007, 09:34 AM   #8
ob1   ob1 is offline
Transmissions are not my forte.
I can say this though, gearing these 200's for max speed will definitely increase the load on the whole engine. Add hilly terrain for more stress. I'm guessing most here {myself included} are no longer svelte, more stress.
I thrash my 163FML2 engine whenever I ride it, but the Honda chassis is much lighter, and my gearing is 15/48, and I have had no problems with the motor at all.
But still, the tranny shouldnt fail so soon after installing the new engine.
My guess is that some excess casting debris may be floating around in some of the engines, galling bearings and causing failures.
Old 06-03-2007, 01:21 PM   #9
I meant to take it apart before returning it but I never found the time.
Frostbite
Old 06-03-2007, 07:23 PM   #10
katoranger's Avatar
This is not encouraging, but I haven't looked close enough to determine if mine is transmission related. Thanks, Allen
Old 06-04-2007, 02:19 AM   #11
Beerslayer   Beerslayer is offline
This is ugly. My GY 200 has added a pretty nasty vibration when it is warmed up. I was wondering if it was falling apart. Think I will drop the oil and see what's floating around in there.
Old 06-04-2007, 01:01 PM   #12
We had notthing floating around in the oil when we changed it, but the transmission was blown.
Old 06-04-2007, 01:56 PM   #13
allfunmotorsport   allfunmotorsport is offline
All the real nasty stuff gets stuck to the permanent magnets in the flywheel on these bikes i find when you drop the oil then pull the stator cover off and that's where you'll find debris
Old 06-04-2007, 05:26 PM   #14
ob1   ob1 is offline
Cast aluminum cases.... aluminum is nonferrous.
Regardless, without anyone actually ripping one down and finding the problem, we are all guessing.
Old 06-05-2007, 12:37 AM   #15
I'm trying to keep the motor so I can do a tair down. hopefuly we will find out.
