Old 05-28-2007, 11:36 PM   #1
jkomp316   jkomp316 is offline
Send a message via AIM to jkomp316
Wierd headlight thing?
Its not really a problem? But the headlight on my GY-5 gets brighter when I apply the brakes? You would think it would dim with the added load of the rear brake light, but it actually gets brighter?
Why is it doing this and how can I make it "brighter" all the time?
Does that little side bulb change intensity?
Old 05-29-2007, 06:53 AM   #2
ob1   ob1 is offline
Could be a bad ground connection in the headlight circuit, or undersized wiring.
Old 05-29-2007, 08:27 PM   #3
katoranger's Avatar
My hi beam burnt out already, but mine dims when the brakes are applied and the engine idles. My low beam I can't really tell. The little bulb doesn't do much.
This is an area needing improvement. I am considering rewinding the stator for more output.
Allen
Old 05-29-2007, 10:41 PM   #4
AZ200cc   AZ200cc is offline
If my amp/volt gage is correct, My bike puts out 16..Probably cooking my battery. 8O
Old 05-29-2007, 10:54 PM   #5
katoranger's Avatar
I don't know if the voltage regulators are very good on these bikes. Allen
Old 05-29-2007, 11:02 PM   #6
I doubt they are, But my light is bright..It just points straight down
I will make a brighter h1 bulb work in it and do some grinding to make it point higher.
Old 05-29-2007, 11:15 PM   #7
katoranger's Avatar
I plan to adapt something easier to find bulbs for.
Allen
Old 05-29-2007, 11:26 PM   #8
stixx3969   stixx3969 is offline
Have you checked your headlight fluid? :wink:
Old 05-29-2007, 11:41 PM   #9
Headlight fluid was fine...the blinker fluid was a little low 8)
Old 05-30-2007, 01:57 AM   #10
This is what I think...
The brake light and "winkers" run of the battery. i.e. you can use them when the bike is not running.
The headlight and dash lights run off the stator. i.e. they only turn on when the bike is running.
When the brake is applied, the two circuits are linked momentarily. The headlight then pulls power off the battery while these are linked. Causing it to glow brighter.
I have tested this with the turn signals as well, they also brighten the headlight when they flash.
Old 05-30-2007, 08:02 AM   #11
red2003   red2003 is online now
Not so sure about that. ALL my lights, headlight included, work just fine with the switch in the ON position, engine NOT running. Also, these bikes will run and function normally, lights too, with NO battery even in there, so I don't believe there is two separate lighting circuits. That would make no sense. OB1 has it correct, you have a ground problem.
Old 05-30-2007, 10:56 AM   #12
I've already tried running another ground to the headlight. It still did it. I even took the grinder and re-did all my frame grounds. Mine is a GY-5, the headlights and dash lights do not turn on without the engine running.
Old 05-30-2007, 04:44 PM   #13
katoranger's Avatar
The headlight/taillight on my gy-2 only operate with the engine running also. The must be only powered by the stator. The winkers and brake light work off the battery. I suppose it could all be wired to be run off the battery to keep a more consistent lighting.
Allen
Old 05-30-2007, 10:23 PM   #14
On my *Whatever it is* The everything works with a turn of the key. All the lights turn on and the horn.
Old 05-30-2007, 10:32 PM   #15
My "what ever it is" is the same. Street legalized, they changed alot, blinkers and manditory low watt emergncy light. All on with the twist of the key. Xinyue Easy 150cc. Can you check Ob1's advice?
