Old 04-06-2012, 12:45 PM   #1
recracer   recracer is offline
recracer's Avatar
plastic surgery for the viva
Old 04-06-2012, 12:47 PM   #2
Git 'er done! :P
The old nip and tuck.
Priced right too. :wink:
Old 04-06-2012, 01:46 PM   #3
recracer's Avatar
Originally Posted by FastDoc
Git 'er done! :P
Cheap enough . 16 and change for the taillight everything else, fabracated from things i had around the house
Old 04-06-2012, 02:40 PM   #4
That looks a lot like the light I installed on my TW. Yours looks great!
Old 04-06-2012, 03:55 PM   #5
recracer's Avatar
thanks weld it is this one from Ebay http://www.ebay.com/itm/190610082329...84.m1439.l2648
Old 04-06-2012, 04:50 PM   #6
Yep, very similar to mine, except that I don't have the smoked cover. The screws that held it together were far too thin for my liking, so I carefully drilled the pastic out and used stainless socket head cap screws that are 4 or 5mm in diameter, along with nyloc nuts.
Old 04-06-2012, 10:09 PM   #7
You did a nice job, Ron. What is the white material you used to fill the space vacated by the old tail light?
Old 04-07-2012, 12:09 AM   #8
recracer's Avatar
Spud the fill panel and the tail light mount are all made from 4x4 vinyl post sleeves i had left over from my deck . sparingly warm with indirect propane torch and bends to whatever you need it to do . I used a bench vise to get straight bends . i used jb weld to retain a panel on the bottom of the fender ,so the top panel would sit flush and have somthing to glue it to .
Old 04-07-2012, 12:12 AM   #9
zingshoen   zingshoen is offline
zingshoen's Avatar
great job! paint next?
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 04-07-2012, 11:53 AM   #10
Ron, what is your shop floor coated with?
Old 04-07-2012, 12:37 PM   #11
recracer's Avatar
weld it is home center (Lowe's ) 2 part epoxy http://www.bing.com/images/search?q=...FD2FED&first=0
Old 04-07-2012, 12:50 PM   #12
recracer's Avatar
Before i got it dirty Home garage
Old 04-08-2012, 02:16 AM   #13
Wow! Are you happy with that floor? It looks great!
Old 04-08-2012, 02:09 PM   #14
recracer's Avatar
I like the floor allot . Was a huge pain in floor prep , the floor was painted and epoxy should be down directly on the concrete . Had to grind the paint off with a diamond cup on a hand grinder . I did have some hot tire lift ,in a spot that was troweled to slick when it was poured . If i ever re-coat it , i will leave out the traction grit . The grit makes it harder to sweep out things like grass clippings
Old 04-08-2012, 05:38 PM   #15
Good to know. The floor in my new house is brand new and shouldn't require much prep. I used a 2 part epoxy in one of my California homes and liked it. The only downsides were air bubbles in places from the concrete outgassing (?) and motorcycle kickstands would quicky scrape through it.
I want a nice garage. It will be fully insulated, heated, sheetrocked, pained white, and I plan to light it up like an operating room. A nice light grey floor will be a nice touch.
