05-27-2007, 09:56 PM | #1 |
Hi Bird has Lifan Engine / same bike as Lifan? Parts?
Hi guys,
I just bought a Hi Bird QH200GY, it has a Lifan Engine, is the bike a Lifan or is Hi Bird a seperate brand using Lifan engines? Can I buy Lifan parts for the bike? Will Japanese parts work? I have had a YamaHondaSukiaki before, I know it works with Japanese bikes allot, has anyone bought parts for their chinese bikes at Japanese bike dealers? I REALLY need a spacer, washers & nut for my rear axle BADLY!!! Any info appreciated, been looking at some of the old posts a little at a time. Problem is that the parts are gone so I don't even really know what I need and what they look like, dimmensions, etc. If someone could email me a high def closeup of the wheel area of the rear axle nut side I would really appreciate it. If there is a spacer there would appreciate knowing the length. Thanks! Dan coilerdude@yahoo.com[/b] |
05-27-2007, 10:08 PM | #2 |
Check with Tom at www.rpmrush.com.He is a dealer on this site and has been selling the Hi-birds.He's located in grenada,ms about 90 miles or so south of memphis.
yamaha vstar 650,unknown chinese 4 wheeler,johnny pag 250 spyder,lifan gy-5 |
05-28-2007, 04:39 AM | #3 |
Dan,
The axle nut's easy it's 14mm dia x 1.5mm pitch. The spacer would depend on which rear brake you have, disc or drum? My disc has a spacer on the sprocket side, which I'd think would be the same on the drum brake and the caliper bracket acts as a spacer on the other. Jonathan. |
05-28-2007, 11:30 AM | #4 |
The Hi Bird should have a drum rear brake, I think. You can make a spacer out of a piece of pipe. Just stick the wheel in there and see what you need to make up the difference. Cut it a little long as the rear wheel assembly fits in there pretty tight. Get the nut at you local hardware store and viola!
06-03-2007, 11:05 PM | #5 |
Very helpful info, THANX!
Thanks for the info, very helpful! 8)
