hi-bird 200gy problem ? help
just got my first batch of these in the shop today and the first 1 had a problem.
the speedo don't work but the odermeter does. but it rolls backwards. i have not had anytime to play with it yet.maybe someone has a fix? anyone every have this happend to them?its a new 1 for me.lol |
Simple!!
The cable is rotating backwards, is the front wheel and speedo drive correctly assembled? I know this because I once had the front end of a trail bike apart, and 2 years later when I came to put it back together I got everything the wrong way round, quite easy if you have a single leading shoe brake and everything is down to nuts and bolts.
Jonathan. |
That could be the problem, Gregg. Try moving the cable drive to the opposite side of the wheel where it will be turning in the other direction and see if that will correct it.
RPM - REV IT UP! (REDLINE is OPTIONAL) Feel the RUSH ... it gets better all the time! |
