Old 01-15-2012, 01:18 PM   #1
kens   kens is offline
07 gio beast chain tensioner
Hey guys
I need a photo of what the proper chain tensioner or a good make shift one should look like so I can fix the missing one on our quad.
Also open to any other ideas to fix this.
thanks
Old 01-16-2012, 12:07 AM   #2
I think this is what you mean: Yamaha Chain Puller
Old 01-16-2012, 09:48 PM   #3
No its the idler on the end of a metal arm that is spring tensioned to take up the chain slack but keep the tension correct.
Old 01-17-2012, 12:57 AM   #4
I have no such arm on my '07 Beast. It slaps the swingarm occasionally, and I might cover it with some UHMW plastic.
Old 01-18-2012, 01:03 AM   #5
well mmmm then . I thought that it was missing off the swing arm as there is a 14 mm stub on the inside of the swing arm that I figured was for it. Possibly that it is just "extra" and was never used.
Old 01-18-2012, 01:28 AM   #6
Ah, I know what you mean. I have a replacement swingarm on my Beast that does not have that stud, but my original swingarm did. In either case, there was no tensioner.
Old 01-18-2012, 09:32 AM   #7
case solved....Thanks
