Old 05-20-2007, 08:27 PM   #1
shammash55   shammash55 is offline
Send a message via AIM to shammash55 Send a message via Yahoo to shammash55
oil grades and styles questionair
this is a lil poll i am curious about, i run rotella 15-40, looking for what everyone uses.
it takes the insane to keep the world sane
Future 2015 csc rx3
Old 05-20-2007, 10:53 PM   #2
bfe71730   bfe71730 is offline
Send a message via MSN to bfe71730 Send a message via Yahoo to bfe71730
Castrol 20/50, use it in all my toys
2004 KAZUMA CHEETAH 200
2001 Yamaha Big Bear 400
1986 Honda ATC 250ES
1983 Honda ATC 200X
1974 Kawasaki KE100
Old 05-20-2007, 11:16 PM   #3
ambassador   ambassador is offline
Sham,
Read through the forums....
06 Lifan 200 GY-5
Old 05-20-2007, 11:59 PM   #4
FMYStreetRacer   FMYStreetRacer is offline
+1 on reading through the forums or even doing a search.
but.... don't use anything with a api rating higher than sj and you'll be fine. i run repsol 15-50 mineral oil in mine.
Roketa DB-07a
HID Headlight
Old 05-21-2007, 07:46 AM   #5
cycleway4   cycleway4 is offline
yes,...lots written about this.............but Honda GN4 10-40 anyway.
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 05-21-2007, 10:26 AM   #6
FreightTrain   FreightTrain is offline
im using valvoline 20w50 motorcycle oil
The Journey -IS- The Destination
Old 05-21-2007, 10:32 AM   #7
30-Arider   30-Arider is offline
Rotella here as well; especially for break in! High Zinc content does very well with hydraulic flat tappet designed camshaft and lifters. For me living in Florida I typicall run 15/50 or 15/40. May switch to full synthetic Wal-Mart brand..very cost effective.
Old 05-21-2007, 10:50 AM   #8
red2003   red2003 is offline
What does this have to do with our China Bikes???
Old 05-21-2007, 11:04 AM   #9
Jim   Jim is offline
I believe it is Motul 10w40 mineral
Old 05-21-2007, 06:30 PM   #10
katoranger's Avatar
Using Rotella 15w40 for the breakin period then going to Amsoil or Mobil 1 synthetic.
Allen
Old 05-22-2007, 10:01 AM   #11
Out of curiosity, would the Mobil 1 synthetic for cars have the same foaming problems as standard oil when used in a motorcycle? I wouldn't think so, but I'm no oil expert.
I've used Valvoline 10w-40 for motorcycles and Castrol 20w-50 for motorcycles ever since I found out about the foaming issue with conventional oil.
Jason
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
Old 05-22-2007, 01:17 PM   #12
Just saying because there has been a huge probelm with hydraulic camshaft failures over the past 5 years in the auto industry and it has been linked to removal of zinc in most oils as it clogs catalytic converters. So higher zinc content and friction moving parts such as rings, rocker arms if you have a push rod style motor, even an OHC motor where there is not a roller type cam this high zinc can always help. If deisel motors with super high compression can run it Id bet its pretty good for a small 200cc air cooled single cylinder bike that works pretty hard. Just giving opinion..did I ruffle a feather cause I didnt mean to.
Old 05-22-2007, 04:03 PM   #13
but how well do they perform with wet clutches? and what about clutch wear? i have no idea myself
Old 05-22-2007, 04:53 PM   #14
[quote="FreightTrain
but how well do they perform with wet clutches? and what about clutch wear? i have no idea myself[/quote]
I run Rotella in my YZ450F for the past 2 years and my wife's PitsterPro all with no problems and have not had to replace friction discs on either bike yet. Thats all my expereince.
Old 05-22-2007, 09:31 PM   #15
the problem with running newer car oils is that they have a high moly content. our clutches are border line as it is. trust me guys run nothing higher than a API SJ rated oil, your clutch will thank you.
no need to run synthetic. our bikes have no oil filter so we should be changing the oil way before it ever has a chance to break down. i change mine every 500 miles. Repsol mineral based oil is $4.99 a liter at the local bike shop so $5 2 times a month is fine for me and my clutch slips allot less now that i stopped running car oil in my bike.
Roketa DB-07a
HID Headlight
