09-14-2011, 11:42 PM | #1 |
2011 x31 valve adjustment
I bought a 2011 gio x31 250. It is the overhead cam motor. Has anybody ever done a valve adjustment on this bike? What are the specs?
Thanks |
09-15-2011, 07:43 AM | #2 |
the MD33E (223) ancestor
Data copied from http://www.ride-inc.net/file/32/data.pdf IN /EX 0.10mm http://sawmee.jugem.jp/?eid=187 |
09-15-2011, 08:55 AM | #3 |
I wish I could read chinese for that write up
09-15-2011, 10:13 AM | #4 |
You can certainly search for XR200R valve adjustment specs and procedure. That will do nicely.
09-15-2011, 10:21 AM | #5 |
Won't the specs and procedure be different as it is a different motor?
09-16-2011, 01:35 AM | #6 |
It's a virtual clone of the XR200R. In fact, it's even closer to a CRF230, because it has electric start.
Doesn't really matter, because the engine doesn't know what name is on the outside. It boils down to the same procedure: find TDC on the compression stroke, set the valves to spec and have a nice day. The valve clearance specs you find for an XR200R will be just fine.
09-16-2011, 06:42 AM | #7 | |
btw: That page is in Japanese. Distinguish Sinosphere in their "modern" writing isn't that hard if knows "how" :wink: |
09-17-2011, 09:24 PM | #8 |
Thanks for the help guys. I found an awesome writeup on the crf230 valve adjustment if anyone is interested
http://nonderivative.com/motorcycles...alveclearance/ |
09-18-2011, 12:36 PM | #9 |
That's exactly the procedure for my '96 XR250R, except I don't have the fancy tool; I use small Vise Grips (very gently).
09-18-2011, 02:54 PM | #10 |
Good to know because I didn't really want to drop 50 bucks on that tool for the amount I would use it.
09-18-2011, 03:46 PM | #11 |
I had a quick look online for a cheap version of that tool, but haven't found one yet. Maybe Tusk makes one.
