Old 06-13-2010, 08:54 PM   #46
ErT   ErT is offline
Send a message via AIM to ErT
pics
i do not know the model number of this anyone happen to have an idea?? looks like the db-07 on the roketa site
anyone know a sprocket type that will fit heres a pic of the stock one
and is this where the petcock valve should be? if so where does it go from there hahaha ill have to take the side panels off
Old 06-13-2010, 09:23 PM   #47
TheRealWorld   TheRealWorld is offline
Should be the DB 07. I think DB stands for dirt bike
Old 06-14-2010, 03:56 PM   #48
It appears to be a DB-07 to me, also.
Old 06-14-2010, 04:18 PM   #49
Buzzkill   Buzzkill is offline
It depends on the year, if it's 2007 or older it's and RSM200E, if it's newer it is the DB07, they are identical bikes they just changed the model number for reason.
Old 06-14-2010, 05:02 PM   #50
ErT   ErT is offline
nice thanks its a 2007 600 miles
Old 06-15-2010, 01:21 PM   #51
ErT   ErT is offline
so ever since i bought this, theres been an annoying rattling up in the front of handlebars where all the wires and speedo and everything is so i started messin around and found the screw that holds the bracket to the headlight plastic was totally snapped.. hour or so of diggin through old screws and i found one that fit... no more rattle
Old 06-15-2010, 01:45 PM   #52
Good repair. Free, except for the time.
Typical ChinaFixer experiance!
Old 06-16-2010, 02:55 PM   #53
ErT   ErT is offline
lol for sure
Old 06-17-2010, 01:13 PM   #54
Frog   Frog is offline
Re Sprockets - I have a pushrod GY 5 and the standard 17/46 is a good road / trail compromise but there would be better options if you only do road - maybe 17 / 42.
I would not go too small on the front sprocket as the chain will probably rub even more on the swinging arm.:roll:
I'm a heavy chap and my bike cruises around 60mph comfortably with the standard 17-46 set up
Frog
Old 06-17-2010, 10:34 PM   #55
ErT   ErT is offline
Frog
sweet i think ill try the 46 or 44 rear most people have been recommending that... still will be riding offroad just more onraod
Old 06-25-2010, 02:05 PM   #56
ErT   ErT is offline
quick question... everyone says the jtr 269 44 tooth but i cant find the 44 tooth anywhere... only a 45 tooth... would that still work?
Old 06-25-2010, 03:08 PM   #57
Cal25   Cal25 is offline
yes it will
Old 06-25-2010, 06:17 PM   #58
I run the 45 on mine and I am happy with it, can cruise at 60 all day with no problems.
