02-17-2022, 12:13 PM | #46 |
Tbr7.com fuel system page has all the jets and a chart with jetting from different users at different elevations too!
02-21-2022, 11:48 AM | #47 |
Kyle, Thanks for the link to the guide. I was following this guide but, found it on my own after considerable searching. It's a good resource. It appears I have some hardware fasteners that are different than than those noted in the guide and/or larger qty. So far, I have not found any defects or poor assembly from the factory.
02-21-2022, 12:11 PM | #48 |
Ordered the PZ30 carb upgrade and jets. That should be plenty of adjustment to get me going out of the gate. I can always upgrade to better carb if I make other upgrades such as exhaust.
02-21-2022, 06:49 PM | #49 |
No. I haven't pulled the cover. My use is mostly off road. I like the stump jumping ultra low gearing. Some people gear these things really tall so that they can go 70mph. I'd rather ride my Bandit GSX 1250 at higher speeds. It is made for it, and has the power to do it comfortably and confidently (understatement!). I hear some scary stories about wobble and shaking over 60 on dirt bikes. It takes a stiff frame, stiff wheels, and a tight/strong triple clamp to go fast confidently. Knobbies add to the instability, but I swapped out the dual sport tires for knobbies.
If I change it, I will be getting a slightly larger rear sprocket. Then 2nd gear will be a crawler, and 1st gear will be the creeper! |
02-21-2022, 07:18 PM | #50 | |
What are you going to do with your original PZ30 clone carb? I must be misunderstanding the "PZ30 carb upgrade". |
02-22-2022, 08:48 AM | #51 |
Thumper PZ30 clone. See link, https://www.amazon.com/dp/B073SVJF2Q...SIN=B073SVJF2Q
It's basically the same as factory carb. I'm confident you're approach, jets and adjustment will result in excellent results. I may end up following your lead if I don't like this carb when it shows up. With this carb yYou don't have to slot the bowl screws to disassemble like the factory carb and I believe you can adjust needle position using notches in needle rather than washers. Regardless, my understanding is this carb still needs to be rejetted. I'll start with #108 or #110 and 36 pilot. I plan to leave the exhaust stock for now but will remove the restriction in the air box inlet design. |
02-22-2022, 09:54 AM | #52 | |
02-22-2022, 10:16 AM | #53 |
Yes, Found the jets and ordered them. I'm pretty proficient working on motor stuff. Just new to the China bike and scooter thing. Nice to get more use out my metric stuff than SAE for a change I have the tools I need to modify the stock carb and still may do that if I don't like the one that shows up. I'll let you know what I have in the stock carb and new one as far as jets when I get to that. I tried to replace front sprocket last evening and ran into a problem. I'll post that under my "chain" post.
02-22-2022, 10:24 AM | #54 |
The issue with some of the carbs was that we didn’t have a source for the jets ,some used mikuni jets ,some keihin ,some used something completely different .Most of them have been figured out now ,,but back in the day we would take a carb apart and possibly wait a few weeks to get the jets ,so the answer was to order a new carb with known jets so it can be ridden right away ,and no need for a Dremel for the people who didn’t have one .
02-22-2022, 01:10 PM | #55 | |
The OEM carb will need rejetting too. Either way, a couple of weeks with imperfect carb, if you are riding in the snow right now (!) won't hurt. Think about it, lots of people ride with improperly jet motorcycle carburetors for their entire life!! |
