Old 07-31-2018, 07:25 PM   #46
hnu13   hnu13 is offline
is the carb really close to the frame on yours? or did i buy the wrong adapter?
Old 07-31-2018, 07:31 PM   #47
Its in about the same position as the stock pz30.
2004 Honda ST 1300
Old 07-31-2018, 08:20 PM   #48
i ordered the one you have linked, the carb is just barely clearing the frame though
Old 08-01-2018, 08:13 AM   #49
I looked at mine last night. I have about 3/4" clearance between the carb and frame.
2004 Honda ST 1300
Old 08-01-2018, 08:36 AM   #50
ive got like 1/32 of clearance... cant be right
Old 08-01-2018, 08:48 AM   #51
The one I used is the one I linked. I wonder if they sent you the wrong one or sent me the wrong one that worked. I'll look to see if there is a part number on it.
2004 Honda ST 1300
Old 08-28-2018, 10:53 PM   #52
MDStroup   MDStroup is offline
MDStroup's Avatar
Where you ever able to figure out what it was?
Old 08-29-2018, 12:21 AM   #53
Sclark1013   Sclark1013 is offline
This sounds great! Does anyone think the Keihin PWK 30 carburetor and the angled carburetor adaptor would fit with the TT250? The easy access to the idle mixture screw sparked my interest.
Old 08-29-2018, 06:47 AM   #54
I don't see why it wouldn't work. The hawk and TT250 use the same type head.
2004 Honda ST 1300
Old 08-29-2018, 07:33 AM   #55
No, sure didn't.
2004 Honda ST 1300
Old 08-29-2018, 09:57 AM   #56
ChrisWNY   ChrisWNY is offline
ChrisWNY's Avatar
Hi Jerry - does the Keihin PWK 30 carb intake fit into the airbox without modification or is the pod filter a must? Considering ordering one. Thanks!
2018 RPS Hawk 250cc
Mods so far:
1. Mikuni VM26 Carburetor w/#115 main jet
2. 17T/45T JT sprockets
3. JT 428 X-ring chain
4. Air box mod
5. Hawk Digital Cluster
6. Aftermarket IMS shift lever
7. Performance Aftermarket Exhaust
8. 295mm Nitrogen Gas Monoshock, 20W oil front forks
Old 08-29-2018, 10:05 AM   #57
The existing intake piping will be too small of a diameter. I was going with a pod filter from the get go. You could make it work with the right silicone elbow coupler. https://www.ebay.com/sch/i.html?_fro...elbow&_sacat=0
2004 Honda ST 1300
Old 08-29-2018, 10:16 AM   #58
ChrisWNY's Avatar
Perfect, thanks...the only drawback I can see with the pod filter is water resistance (it could suck water into the carb during a heavy downpour or submersion), otherwise I'm sure it opens up airflow substantially to the carb. I went with that first eBay link - 90 degree 2" silicone elbow coupler. I'll get some hose clamps to secure it to the intake and the carb inlet. Ordered the Keihin carb from Aliexpress. Can't beat the price and it'll be nice to have better fuel flow into the engine. Thanks for providing the links in your earlier post, huge help.
2018 RPS Hawk 250cc
Mods so far:
4. Air box mod
Old 08-29-2018, 10:23 AM   #59
I went ride about a month ago at the spillway. It rained pretty much the whole time we were there. Went through some deep water holes. I had no problems with it sucking in any water. Most of the filter is covered. What little that is exposed had some mud fling on it but filter never got wet enough to cause any issues. I did spray it with some K&N filter oil so water pretty much just beads off.
2004 Honda ST 1300
Old 08-29-2018, 10:45 AM   #60
ChrisWNY's Avatar
Did you end up just cutting off that tube from the air box and leaving it in place? I guess it could come in handy for tool storage underneath the seat. Could make a little hinged door where the air tube used to be located...
2018 RPS Hawk 250cc
Mods so far:
4. Air box mod
