#46 |
is the carb really close to the frame on yours? or did i buy the wrong adapter?
#47 |
Its in about the same position as the stock pz30.
#48 |
i ordered the one you have linked, the carb is just barely clearing the frame though
#49 |
I looked at mine last night. I have about 3/4" clearance between the carb and frame.
#50 |
ive got like 1/32 of clearance... cant be right
#51 |
The one I used is the one I linked. I wonder if they sent you the wrong one or sent me the wrong one that worked. I'll look to see if there is a part number on it.
#52 |
Where you ever able to figure out what it was?
#53 |
This sounds great! Does anyone think the Keihin PWK 30 carburetor and the angled carburetor adaptor would fit with the TT250? The easy access to the idle mixture screw sparked my interest.
#54 |
I don't see why it wouldn't work. The hawk and TT250 use the same type head.
#55 |
No, sure didn't.
#56 |
Hi Jerry - does the Keihin PWK 30 carb intake fit into the airbox without modification or is the pod filter a must? Considering ordering one. Thanks!
2018 RPS Hawk 250cc Mods so far: 1. Mikuni VM26 Carburetor w/#115 main jet 2. 17T/45T JT sprockets 3. JT 428 X-ring chain 4. Air box mod 5. Hawk Digital Cluster 6. Aftermarket IMS shift lever 7. Performance Aftermarket Exhaust 8. 295mm Nitrogen Gas Monoshock, 20W oil front forks |
#57 | |
#58 |
Perfect, thanks...the only drawback I can see with the pod filter is water resistance (it could suck water into the carb during a heavy downpour or submersion), otherwise I'm sure it opens up airflow substantially to the carb. I went with that first eBay link - 90 degree 2" silicone elbow coupler. I'll get some hose clamps to secure it to the intake and the carb inlet. Ordered the Keihin carb from Aliexpress. Can't beat the price and it'll be nice to have better fuel flow into the engine. Thanks for providing the links in your earlier post, huge help.
#59 | |
#60 |
Did you end up just cutting off that tube from the air box and leaving it in place? I guess it could come in handy for tool storage underneath the seat. Could make a little hinged door where the air tube used to be located...
