Old 12-25-2019, 04:18 PM   #46
ikeus685   ikeus685 is offline
Send a message via Yahoo to ikeus685
No carb work has been done "yet" I decided that when I do that.. The original ie $70.00 Japanese Makuni is what I will go with. Fork oil up grade.. I weigh in the 180's and the 20wt oil in place of what came from the factory looks to be a good choice.
47 mph so far
Did you see what showed up?
The Kepspeed swing arm is a welded piece of art!!Will be installed at a later time.. Once I get an idea how to.. improve the rear end.
Skid plate with and assortment of parts to hopefully adapt for this bike.. Designed for the BMW G310GS
Foot pegs are e bay.. Need to grind off a bit of metal so foot pegs can open fully
Old 01-03-2020, 06:04 PM   #47
SleepyC   SleepyC is offline
Originally Posted by scoot newb View Post
NO! Daytona 212 4v
Don't want that, I'd buy a bigger bike.
Just want smooth power to 50 - 55. Got that.
All is good.
Now, I need a rear shock, what fits that I can adjust?
Old 01-15-2020, 08:33 PM   #48
kirbo7106's Avatar
Originally Posted by KingMonk View Post
the hellcat is old school with big ugly headlight.
Why’s it gotta be a “Big Ugly Headlight”? Where’s the love?
Why can’t it be a “Wind splitting, aerodynamic, speed enhancing, device that emits a beautiful ray of sunshine”?
All we are asking for is a little love people!
Dan-O
-2018 Tao Tao HellCat - DOA
Old 01-15-2020, 08:39 PM   #49
scoot newb   scoot newb is offline
scoot newb's Avatar
T I looked at Mikuni VM22 carb but im confused to which one people are actually using, the mikuni is $70 the knock offs are about $30 but they are all bigger bore like 26mm not 22mm.
Most people are using the clone carbs. The vm22 is not a 26mm carb. The inlet inner diameter is 26mm but the slide is not. The slide is what determines the carb size. I wonder what a VM26 would run like on the stock motor.
Old 01-15-2020, 08:45 PM   #50
scoot newb's Avatar
https://www.ohlinsusa.com/parts/honda/grom-msx-125
Old 01-15-2020, 09:33 PM   #51
kirbo7106's Avatar
I was looking at this one from YSS on Amazon for $188.
Enjoy the Ride!
Dan-O
Old 01-16-2020, 02:07 PM   #52
wlfpck   wlfpck is offline
Here's another option:
https://www.aliexpress.com/item/4000...chweb201603_55
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
Old 01-17-2020, 12:28 PM   #53
Photogromer has a video about that YSS shock over on Youtube, they liked it .
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 09-02-2020, 02:53 AM   #54
Nicthegreat420   Nicthegreat420 is offline
I’ve installed a 26mm carb, have to upgrade the intake manifold tho. Close to a mini carb but not one.
Old 09-02-2020, 02:54 AM   #55
Glad to see this thread isn’t and dead as I saw earlier on. Anyone having carb adjustment issues like me ? Won’t even fire up just turns over for days with spark. Fuel gets to the carb n bowl. Float stuck open/closed?
Old 09-02-2020, 03:31 PM   #56
ripcuda   ripcuda is offline
ripcuda's Avatar
What happens when you squirt some gas (or starter fluid) down the carb throat (hold throttle open when you squirt it) and try to start it? Does it fire off, run for a second and die?
I've got a vm22 mikuni (clone) carb on my stock HC. Runs great after tuning.
Cheers!
'20 TaoTao Hellcat 125 "grommet"
'04 Yamaha TTR-125LE
'00 Yamaha TTR-90
'07 Kinroad XT200GY Runmaster (sold)
'07 KMD GY6 150cc ATV (sold)
'07 Kangchao 250cc ATV Monster (sold)
Baja Moto DB-30 "Doodlebugs"(x3) (sold)
'06 Hi-Bird 200 parts bike (sold)
Old 09-02-2020, 06:56 PM   #57
[QUOTE=ripcuda;345659]What happens when you squirt some gas (or starter fluid) down the carb throat (hold throttle open when you squirt it) and try to start it? Does it fire off, run for a second and die?
It tries to cough. Coughs with a chain rattle.
Sometimes it just doesn’t do anything. Post a video of how your carb is adjusted cuz I swear the videos I’ve seen online are worthless to this 26mm carb.
Old 09-02-2020, 07:14 PM   #58
Hopefully this shows the pics, I can’t send the video sound... of the chain as I start this bike.
File Type: jpg 55830814-2452-4294-9F38-94E01CF1231A.jpg (157 Bytes, 752 views)
File Type: jpg B31DDBB1-ACF3-4F58-822F-7A145E4F899B.jpg (157 Bytes, 841 views)
Old 09-02-2020, 07:15 PM   #59
I have an exhaust leak where do I find the correct size gasket for exhaust is it a 30,32,33,34,36 mm gasket? Copper or no..?
Old 09-03-2020, 12:22 PM   #60
ripcuda's Avatar
Check out my build thread...this post explains my tune. I've got the vm22 on the stock manifold/spacer... and stock exhaust (sorry don't know exhaust gasket size).
http://chinariders.net/showpost.php?...8&postcount=10
Cheers!
'00 Yamaha TTR-90
