Old 10-30-2018, 06:24 PM   #16
Whisky   Whisky is offline
Whisky's Avatar
Kinda same issue I had. I read on here I think or could have been on google if the a/f screw needs 3 turns or more out to go up 1 size jet and if its 1 turn or less to go down 1 size. I think most of my issues I had were self inflicted, I just had to have a bigger carb and just had to have a better exhaust. After I got it going good I stayed close to home for a while, just in case but now I ride it all over. I do carry a few tools with me though as you never know.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 11-01-2018, 11:55 PM   #17
Vx21rsjohn   Vx21rsjohn is offline
I put the carb on today, but what did you do with the tube coming off the crankshaft?
Old 11-02-2018, 01:49 AM   #18
Whisky's Avatar
The larger hose comming out of the crankcase I put a small air filter on it, that's the crankcase breather. You don't need to drill a hole in the intake tube as I did, it just gets plugged. I think that's all the vac lines I have. I took the EGR off and covered the port with the bracket that mounts the EGR tube onto the head. I took all the emissions stuff off. You can just leave the crankcase hose with nothing on it as well.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 11-02-2018, 05:41 AM   #19
Thank you
Old 11-04-2018, 01:54 AM   #20
Did you use the stock carburetor throttle cap on the new carb or did you use the one it came with. I don't think mine is seated completely and I'm using the stock cap on the new carb.
Old 11-04-2018, 10:28 AM   #21
Whisky's Avatar
Im using the one that came with the new carb but replaced the 90* bend cable guide with the straight one. I can almost guarantee u have a vac leak or the choke is on.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
