04-30-2007, 10:54 AM | #16 |
Newb, no it's not normal for the bike to creep like that. Sounds like you need a clutch cable adjustment. Ambassador, that Camry motor was more then likely broken in on a motor stand before it ever made it into the car. That's why some come from the factory with synthetic already in them.
04-30-2007, 02:48 PM | #17 |
I tried it again today, no creeping forward in 1st with clutch ingaged. I figure the plates wern't lubed after the oil was changed. Anyway it's fine now. Though the clutch cable probably needs lube as squeezing the clutch handle feels too stiff.
Can somone point me to the lubing the clutch cable for newb's thread with pictures for newbs page? thanks. N2R 150cc xingyue easyxy |
04-30-2007, 03:03 PM | #18 |
The best way I found to lube cables is to take the cable off coil it so you cab put it in a tub of oil for a bit then take it out and move the cable back and forth. hang it for a bit to let the lube run threw. and repeat till it feels smooth. then wipe it down and reinstall. when you reinstall the cable make sure there are no sharp bends it the cable.
hope this helps |
04-30-2007, 05:12 PM | #19 | |
any kind of oil? 10w30 sewing machine 3in1 wd40? N2R :? |
04-30-2007, 05:36 PM | #20 |
sorry, what I should of said is: remove the cable from the bike..Coil it small enough, so it will fit it to a coffee can then puor some motor oil in to the can.5w30 10w30 10w40. I do things the long slow way often. there is (I'm sure)faster easyer ways, but this way you can inspect the condition of the cable and housing to give you peace of mind. Also you will get to know alot more about the bike by taking it apart and putting it together your self. you can just spray any lube on the cable at the leaver and work it and hope that it has been installed right.?
04-30-2007, 07:32 PM | #21 |
The best way I have found to Lube Cables is with a MP Cable Luber.
http://chinariders.net/gallery2/main...avId=x62ff093a
Thanks, Bruce @ Endless Journey Cycles "Phone Calls Only" ~330-274-0098~ Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST. Dealer for: Lifan, Crossrunner ATVs. http://www.endlessjourneycycles.net |
04-30-2007, 09:36 PM | #22 |
maxima chain n cable wax works great!!
The Journey -IS- The Destination |
04-30-2007, 10:17 PM | #23 |
Thanks again to FMY. Picked up a gallon of the Rotella-T Synthetic at WallyWorld tonight for $16 that should net me about 3 oil changes. For a little over $5/oil change it's kind of a no-brainer. I like changing the oil in this thing. Takes no more than 10 minutes including rounding up an oil pan.
06 Lifan LF200GY-5 |
05-01-2007, 07:33 AM | #24 |
Changed the oil last night and rode the bike to work this AM. Maybe I'm going crazy but I actually think the engine is quieter now. Significantly quieter. The "sewing machine" sound is nearly non apparent. Perhaps the oil that was in there from last fall was just bad and was making a lot of noise. Perhaps the Rotella-T Synthetic is all it's cracked up to be. Who knows. All I know is that's all I'll be putting in the bike from now on.
05-01-2007, 01:38 PM | #25 |
Thanks EJ, it looks like the thing to have. Saves me from re-snaking the cable. N2R 150cc xingyue
