front rim oval
So I put a new tube on my front rim. Now my rim is not round. It bounces as I drive down the road....what to do?
#2 | |
Re: front rim oval
Check right next to the rim bead. You'll probably see a raised line running all around the tire. Deflate the tire and push, pull and tug until that line is equal distance from the rim all around...reinflate...ride... and repeat until you get it right. ![]() If you think that looks good... Raise the front tire off the ground, give it a spin and hold a screwdriver along the fork leg til it just touches the top of the rim. You'll see a varying distance at the rim if out of round. I'll check for any videos. You know somebody has one on YouTube. ![]() Found one (several actually), about 5 minutes into this one, the mechanic mentions airing up the tire and checks the bead indicators on each side of the tire. Had to do that with bicycle tires all the time and the one tire change I made on the Lifan. Bill |
i hope it isnt the rim bead , I just spent 2 hours tweaking the spokes to get it from 1 1/2 to just under a 1/2 ince out of round, i will check the bead in the morning
#4 | |
![]() Spud ![]()
#5 | |
Like Spud said, I wouldn't ride it that far out. Unless I absolutely had to for transportation and then slowly. I hope you can get it pulled back in shape. Bill |
How would it get 1 1/2 inches out of round? Did you hit something with it? We are talking radial here and not axial right?
No I hit nothing.it was fine then I pulled the tire off.put a new tube in.put the tire on and went for a testdrive and.bounce bounce bounce. So I took the rim off again and spun it and it wobbled up and down 1.5.
have you tried to pull the tire and tube off and give it a spin ? as said above it could be the tire it self
wow ok so... the tire was not seated perfect, so
?1 how does that happen 2it wont go on no matter what i do ? any ideas? do i need a new tire? 3 i popped the new tube trying to get the tire to seat fully! grrr. |
Here's the answer (courtesy of Spud): http://motocross.transworld.net/1000...p-tire-change/
This video changed my life. I actually enjoy changing tires now. Buy the tools that are shown in the video; totally worth it.
#11 | |
![]() ![]() http://chinariders.net/modules.php?n...ewtopic&t=9080 Spud ![]()
#12 | |
Thanks chap. |
#13 |
I usually dont have too much trouble changing tires but I did notice something different that I am going to do now. I have always taken the second side of the tire off the same side of the rim as the first side.
He took off both sides off of each side of the rim leaving the rim loose in the middle. that looks much easier. That bead holder looked like a worthwhile investment as well. |
#14 | |
![]() ![]() ![]() Spud ![]()
#15 |
I have the same bike as the OP. I recall having an issue similar to his when I first got my bike. The front tire was not seated exactly even and it did have a very slight out of roundness to it. I changed tires and tubes and had a bit of a problem getting the front tire to seat properly.
If I recall correctly, I deflated the tire again completly and lossend the bead of the tire all around. had to go to arond 80 pounds before it got in the right spot. |
