06-20-2010, 04:17 PM | #1 |
baja 150cc atv rear bearings... where to find them?
hi, i have a baja 150 cc atv, the rear bearings are shot. does anyone know where i might find this item? or any dealers have this? is this the same as all other 150cc atv's from china? so could i use bearings from a kazuma or one that vbike.us carries?
06-20-2010, 11:44 PM | #2 |
rear bearings
probadly the best thing is if you can not get a number off of the other bearing.. you can check out the BAJA SITE.. they can help or if you have a local bearing store.. they can match you up with the bearing.. and better ones.. please post your results so others can learn.. thanks ..
06-21-2010, 12:06 AM | #3 |
no numbers, you mean measure the bearing?, i will def post on herewhen i figure this out.
06-21-2010, 02:09 AM | #4 |
I take all of my bearings into a local shop, Precise Bearing in Abbotsford, BC. If you have a local bearing shop, they can likely match it up for you with a better quality Japanese bearing (for cheap).
06-22-2010, 01:21 AM | #5 |
BAJASPORTS.NET
GO TO WWW.BAJASPORTS.NET they have your stuff.. and you can also go to PEP BOYS .. I just googled BAJA 150 and there is alot of stuff.. and wiring diaphrams plus parts downloads.. the bearing looked like a 32006 you can call or see there pic of the rear axle bearing..
