#46 |
Cool, I think I got it.
Looks like real good work, and you did a good job explaining the function. |
#47 |
Thanks. If this helps, here's the 2 components highlighted.
#48 |
Great explanation of what you did and how it works, red2003! It looks good and better yet, it sounds like it works much better than the stock linkage.
I have narrowed down my search for a shock. The shock in the picture below is the stock Showa from a standard Buell XB motorcycle. I had 2 of these last year but sold them on ebay. It should be easy enough to find another one. Hopefully, it will be cheap! I forget the length of the shock but 10" or so! It should be short enough to not require extensive rebuilding of the frame or swingarm mount. The stock linkage will be dumped. The XB shock gives around 5.5" of travel. It even has a pretty blue spring that matches my bike! ![]()
2013 Jeep Wrangler Sahara MOAB 2005 BMW E53 X5 2011 Schutt Industries LTT-HC LQG trailer 2017 Coleman CT200U 1978 Yamaha SR500E 1979 Yamaha XS650 Special II |
#49 |
red2003,
After much studying lastnight, of different designs, I can see what you did with your new links. My links were exactly backwards from the way you did your's. Because the links were backwards they did not work properly and my suspension was essentially a hardtail. It would not move at all. The stock Viva shock was resting on the rear link, locking the suspension in place. What a poor design! I love the bike but it's going to be hard to recommend this bike to friends. Two of them are looking at the Viva now! I may suggest the Rocketa as a better bike. It has the OHC engine but I'm not sure about the rear suspension. I appreciate all the work you did on this and that you posted pictures of what you did here. I wanted to revive your thread and say that I plan to use your pattern. Mine will use two outboard links. This will keep the links out of the way and hopefully make the linkage easier to fabricate by using flat steel for the two links. What a great Forum we have here in chinariders.net!
#50 |
That sounds good Sam. To be honest, I'm not sure I would recommend the Roketa either. The frame, rear suspension included, is identical to the Viva except the Roketa has preload adjustment, but it makes no difference. I can't believe anyone who bought one of these to truley use as a dual sport is satisfied with the rear suspension setup. What a horrible design. Anyway, back to topic. The R1 shock is also 12 in. ctc. FYI, it has 2.2 in of travel before it gets to the bump stop. With the new linkage as I diagrammed out, you'll have close to 9 in of travel, give or take what the bump stop allows. With the rising rate linkage I have about 6 inches of plush travel then it ramps up quick. It looks like the Buell shock has about the same throw as the R1, but if you use my scissor dimensions, you'll also have to move the top shock mount up 9/16 in. If you don't, the linkage is gonna hang way down there. Also, I like the idea of outboard mounts. How do you plan on mounting the bushings back in there??? Keep us posted, and best of luck. You'll never regret doing this mod!!!
#51 | |
To get all the offroad capability I would like I'm going to have to do the linkage mod and that is a pain to do. I see on that "250" Kayak bike they have the linkage right. !@@#$%! |
#52 | |
#53 |
Yeah no doubt. I have an 09 R1 shock and a 2013 FZ1 shock on the shelf in my garage. I kinda feel like they would be too stiff for my though
#54 |
Just not fair.... the dam pictures won't work for me...
