View Poll Results: What kind of work do you do? | |||
Professional (Doctor, Lawyer, etc) | 6 | 18.18% | |
Mechanical | 6 | 18.18% | |
Technical | 5 | 15.15% | |
Computer - Software | 2 | 6.06% | |
Computer - Hardware/networking | 4 | 12.12% | |
Sales | 2 | 6.06% | |
Self-Employed | 4 | 12.12% | |
Service Industry | 1 | 3.03% | |
Stay at home parent | 0 | 0% | |
other | 3 | 9.09% | |
Voters: 33. You may not vote on this poll |
09-13-2006, 02:30 PM | #16 | |
Re: Stiff rear suspension
Yeah, sorry. I see what you mean. But if the rear suspension is really bad, you do have acres of room to modify the bottom shock swinging-arm mount position. You could relatively easily move it forward and down to retain the same ride height, but enabling the swinging arm to have a greater mechanical advantage over the shock. You could do this with a plate which bolts between the original swinging-arm shock mount at one end, and has a new shock mount at the other, as well as a means of stopping it rotating (possibly a bolt through the swinging-arm cross member. This would be a cheap fix I would use if the rear suspension was as bad as mine was initally, but I had your mounts. Just a thought. |
09-13-2006, 03:22 PM | #17 |
The best way I could fix things is to gain some weight. laughs. Seriously though I think I may have found a way with an air adjustable shock. Just trying to figure out a way of getting the funds. Will let ya know...
2000 MZ Baghira |
