Old 08-28-2009, 03:43 PM   #16
Start here, and see if it is helpful: http://www.chinariders.net/modules.p...ewtopic&t=4509
Old 08-28-2009, 04:14 PM   #17
spcamno   spcamno is offline
Thanks for the link!
After watched some of the video what's the main prupose of upgrade the stock oil pump to high volume oil pump?
The 110cc don't even have a filter so what's the benefit from it?
Will the motor runs cooler?
Thanks
Old 08-28-2009, 04:21 PM   #18
TurboT   TurboT is offline
Thanks
High volume pump is someone's make work project. Don't bother.
In fact, the faster the oil runs past the components, the less heat it will wick away, so it would work the opposite.
You have no need for high volume pump.
Old 08-29-2009, 07:32 PM   #19
Thanks again Turbo T,
I would have imagine that is not very useful too!
Old 08-31-2009, 02:05 AM   #20
spark plug repair
when you are drilling out the hole for the helicoil. use a good vacumm cleaner and place it as close as you can .. it will suck out all the filings.. and then when you are done .. crank it over with out any plug in it to flush out any other pieces.. you can always place some grease on a screw driver to help catch any pieces in the head when you turn it over by hand.. take the plug out of the left side and use a socket to turn it over.. taking the head off is a big job for this.. or let them do it.. they do this all the time.. no prolem
Old 09-01-2009, 10:34 PM   #21
Re: spark plug repair
Thanks for your tips!
I haven't decide should I do this myself of having it done by a shop.
Will keep you guys posted.
Thanks again!
