Old 04-23-2009, 02:43 AM   #1
Qingdao   Qingdao is offline
XR200 barrel
Haven't been on this site for a while, but I floated a valve in my LB200-2 (buggered it up good). Anyways it gives me an excuse to do all the things I wanted to do.
I got plans for a 32mm flat slide carb, XR200 jug, and a Wiseco 10:1 piston. NO MORE P FOOT'N AROUND.
BTW: there is a red line on the tack. Apparently they put it there so you know when you should get off the throttle. I was un-aware of this fact when I broke my exhaust valve. :twisted:
<div><a href="http://www.youtube.com/watch?v=X2ilH...s</a></div><br />
Old 04-23-2009, 03:53 AM   #2
Re: XR200 barrel
Originally Posted by Qingdao
Haven't been on this site for a while, but I floated a valve in my LB200-2 (buggered it up good)...BTW: there is a red line on the tack. Apparently they put it there so you know when you should get off the throttle. I was un-aware of this fact when I broke my exhaust valve. :twisted:
So that's the purpose for the red line! Thank you! :roll:
Old 04-23-2009, 08:49 AM   #3
katoranger's Avatar
Make sure to take pics and give details.
Allen
Old 04-23-2009, 02:18 PM   #4
Re: XR200 barrel
...I got plans for a 32mm flat slide carb, XR200 jug, and a Wiseco 10:1 piston...
That sounds like a fun, interesting project. Please do take photos and post them. I have learned very much from the polite, helpful members of these forums.
Old 04-24-2009, 03:46 AM   #5
That is the original problem :roll:
I am pretty sure it was the cause the motor was really hot (running on a stand and not using sufficiant fans) and I had just used some nitrous before I blew it.
This is why I am not going to attemt any kind of boring or anything on this jug.
Old 04-24-2009, 01:09 PM   #6
...That is the original problem :roll:
I am pretty sure it was the cause the motor was really hot (running on a stand and not using sufficiant fans) and I had just used some nitrous before I blew it...
Yikes! Was the valve stem burned into two pieces?
...This is why I am not going to attemt any kind of boring or anything on this jug.
Yes, I see why; 2.5 mm does not give you a lot of material to play with.
Thanks for posting the great photos, Qingdao! If possible, please keep us updated as you continue your project.
Old 04-25-2009, 03:16 AM   #7
Found a jug on the "bay" and went for the leap of faith. I hope it fits. I feel pretty confodent it will.
I haven't mentioned this on this site but there is a problem with the substitution. The XR is an overhead cam not a push rod engine. So a hole will have to be made in the side of the XR cylinder that I purchased. Not to worry the machine shop that is going to be doing the boring to the cylinder can take care of a simple hole to suspend push rod components.
BTW: due to the fact that I am purchasing a used barrel I am going to bore it out to .25mm over the STD of 65.5mm. Not as much for performance as for the fact that a used barrel could have imperfections that a boring will deffenitly take care of. Although, 222cc sounds really good. :P
Old 05-03-2009, 03:06 AM   #8
Yeah, it don't work. The timming track on the XR cylinder is smaller.
Oh well it was worth a shot.
I have found out that the 185 ATC piston does work in the FML 163. So I guess I am on another quest to waste money to find a Wisco (or other high comp piston) 63.5mm or 64mm piston.
Old 06-16-2009, 03:36 AM   #9
Well you may not be able to put an xR200 jug on the china-bike but you can take a Honda ATC piston (which matches the stroke) and cut it down at a machine shop and get some more compression.
Just thought I would let you guys know.
Old 06-16-2009, 09:54 AM   #10
Dragon   Dragon is offline
What's a jug?
Chinabikeless
Old 06-17-2009, 12:27 AM   #11
Originally Posted by Dragon
What's a jug?
Barrel or cylinder. :wink:
Old 06-18-2009, 11:34 PM   #12
TheRealWorld   TheRealWorld is offline
How do you inject the nitrous?
Old 06-19-2009, 01:41 AM   #13
Yeah, I have been thinking about NOT using any more. I was injecting before the carb, but if I decide to continue using I am going to inject in the intake boot.
Old 06-24-2009, 10:09 PM   #14
NOW THATS A HIGH TOP PISTON!
