Old 06-12-2009, 02:02 PM   #1
Staticworth   Staticworth is offline
Send a message via AIM to Staticworth
yeah i figured, the main reason i really wanted to change mine was to be able to re-fit the rear shock directly to the swing arm and maybe get more ride height. Right now i have the set-up that is bolted together. I'd get a picture if i could but I've seen one on here before I'll look for it. it looks like two triangle pieces with three bolt at the lower shock mount
Old 06-12-2009, 02:12 PM   #2
I'd bet the best solution would be a longer used shock off eBay.
You want more ride height? How tall are you? :!:
Old 06-12-2009, 02:21 PM   #3
Yeah, more ride height would be nice. I'm 6'1" and from what i've encountered the rear shock doesn't like offroading
Old 06-12-2009, 02:39 PM   #4
I'm also six one and I'm up as high as I can go. An interesting idea is that if you are mostly doing off road, change tires to the Kenda 760's I have been running. They are much taller than stock and raised the bike at least 3/4 inch while significantly helping it out in soft terrain. Just a thought.
Old 06-12-2009, 02:40 PM   #5
You can also increase the shock's preload.
Old 06-12-2009, 02:59 PM   #6
Hmm that's a great idea, how did you go about changing the preload on the shock?
Old 06-12-2009, 03:02 PM   #7
Mine has a collar on the bottom that screws up or down to change the preload on the shock. Up makes it firmer and sag less (ie, be taller) when you sit on it.
Old 06-12-2009, 06:16 PM   #8
knothead   knothead is offline
Yeah but....
Increasing the preload to raise the ride height will kill the already poor suspension. You'll loose rebound travel which can be bad if you're carrying any speed on rough surfaces. The rear needs to compress about 1/3 of it's total travel with a fully geared up rider's weight in the saddle and an inch or so with only the bikes weight (race sag and static sag). I know my Lifan is sprung poorly, with the correct race sag there is no static sag, which means the spring wrong for my weight.
I had my preload cranked up, but had trouble maintaining traction on and off road (and the rear would bounce under heavy breaking), once I backed it down the bike handled much better and was a bit more comfortable to ride.
Old 06-12-2009, 06:18 PM   #9
Also true. The Great Chinese Tradeoff!
Personally I run mine with the preload dialed 3/4 of the way to the 'soft' end and it ain't soft.
Old 06-12-2009, 11:03 PM   #10
mine doesn't seem to have a collar on it to do that =[
Old 06-13-2009, 07:35 AM   #11
Frog   Frog is offline
Too much extra height (e.g. much longer shock) will also cause problems with the chain run - it will try to cut through the swinging arm where it pivots......... :(
Frog
