#16 |
yep, first thing i did was adjust the cable. it was ok but i added some more play.
Roketa DB-07a HID Headlight |
#17 |
If you do decide to pull the clutch apart, you can send me one each of the steel and fiber plates, and I will compare them to the XR200 clutch.
Dont forget to send the return shipping as well! My suggestion, use USPS Priority mail bag at the PO. When you send it, label another bag with your address in the "TO" spot and throw $4.00 in it, and toss it in. Ordinarily I wouldnt sweat $4, but right now isnt the time... |
#18 |
i can just measure the thickness and diamiter if you want.
#19 |
You would have to measure; Thickness, outer total diameter, outer notch diameter, inner total diameter, inner notch diameter, number of interior splines, number of exterior splines, width of interior splines, width of exterior splines.
Much easier to send one of each and compare. |
#20 |
if i end up needing new ones i'll send the old ones for sure. i just don't want any down time. i think i'm going to just pull it apart and add some washers to the springs and call it a day.
#21 |
Who had the bike that died? Maybe they would send the parts down for comparison? I'm not tearing mine apart until it needs it!
#22 |
calcune i think. that would be cool as hell to compare.
#23 |
It would, but wasn't his a push rod version?
2008 Jonway MC-70-150 2007 Roketa DB-07B (RSM-200E) 2006 Roketa DB-07A (RSX-200E) 1995 Kawasaki Concours (ZG1000) |
#24 |
probly the same clutch. i don't think there is much of anything different from these bikes. i'm currently creating a Rofan myself. i already have a Lifan front rim band and throttle cable. next will probly be a Lifan clutch cable and maybe even some lifan clutch parts if they're needed.
#25 |
Hey guys
I already have a A. Lifan 200 engine apart that had a Major Vibration problem. I'm already in the process of checking on the clutch plates. Bruce
Thanks, Bruce @ Endless Journey Cycles "Phone Calls Only" ~330-274-0098~ Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST. Dealer for: Lifan, Crossrunner ATVs. http://www.endlessjourneycycles.net |
#26 |
Hey guys
#27 |
I am adjusting my clutch to make sure it is fully engaged when fully let out. Has anyone added an extra spring to pull the armature back.
2006 Lifan LF200GY-5 |
#28 | |
#29 |
yeah it's gotten pretty bad now. prettysure i won't be riding the bike again til it's pulled apart.
#30 | |
I added a couple of pics to help understand Jason
