03-23-2009, 06:53 PM | #1 |
here's an easy question
this is the bike in question, http://chinariders.net/modules.php?n...ewtopic&t=7522
Where do I find the oil plug?! lol... |
03-24-2009, 12:38 AM | #2 |
14 views, 0 replies.
that kinda sucks. I realize its a noob question, but I have thoroughly looked over the case and don't see it... I might add that the skid plate which covers the entire bottom is welded on, do I have to pull the engine or my clutch cover everytime I want to change the oil????????? can you say BIKE FOR SALE!!! lol I added a sheng way carb today and she purred, sounded good for a four stroker I REALLLLLLY need to find out what kind of plastics will fit this bike, looks almost like crf plastics, but what year? I'd hate to have to use hanger iron and drill on new plastic :( thanks for any insight and advice 8) |
03-24-2009, 01:19 AM | #3 |
Need more pictures of the engine maybe? I'm not familiar with that bike, do you know what make the engine is? On the left side, in front of the shifter somewhere is there a large bolt (like 23 mm or so), that is where the oil drain plug is on most Lifan engines I've seen.
You could probably cut a hole through the skid plate to access the bottom drain plug easier?
"Be excellent to each other" "We are all human. Let's start to prove it!" |
03-24-2009, 01:22 AM | #4 | |
thank you kindly jim :oops: |
03-24-2009, 08:19 AM | #5 |
No problem, glad you figured it out I meant to say that is where the oil screen is, and it works for an oil drain, there is usually also an actual drain plug on the bottom of the motor.
