Old 03-05-2007, 10:42 PM   #16
stixx3969   stixx3969 is offline
What are you guy using for cable lube?
Old 03-05-2007, 11:25 PM   #17
Jet_Tech   Jet_Tech is offline
Believe it or not, I use the same lube I used on my military rifles when I was in the Marines, its called CLP or Break Free, you can buy it at Wal Mart in the sporting goods section, its awesome stuff, but you will need to get a cable luber which clamps onto the cable and allows you to inject the lube into the sheath rather than all over it. But any kind of lube will work, stay away from WD40 it tends to gum up when it contacts other lube which maybe present in the cable. Another good lube is 3 in 1 oil which you can get any where. Graphite spray is good but hard to get into the sheath.
Old 03-06-2007, 12:22 AM   #18
mdsuave13   mdsuave13 is offline
Send a message via AIM to mdsuave13 Send a message via Yahoo to mdsuave13
i used silicon spray, i just unhooked the top end and filled the end up and moved the cable till it went down the sheath, i redid this process about 46343 times till i felt it was pretty smooth and lubed up.. i would say keep on lubing till you cant take it anymore... that way you know its good to go..
and the sad thing is that i know this will have to be done at least once more this summer and probably every season afterwards.. i may have to spring for a cable lube tool.
My name is Justin, my friends call me Stix.
2008 Kawasaki KLR650 Candy Lime Green
______________________________
I am the official China bike registration Guru For the State of Maryland..... HA.
Old 03-06-2007, 10:15 AM   #19
tzrider   tzrider is offline
http://www.royalenfieldusa.com/cable-lube-p-525.html
I use the above cable lubing kit. I replaced a rather dry clutch cable on the Diamo and lubed up the clutch AND throttle cable to avoid such wear the next time. It had been getting stiff, but as in all things, I was putting off lubing it and it's an easy chore. :roll:
Old 03-06-2007, 11:08 AM   #20
Did I see where someone said that JC Whitney had custom cable kits?
Old 03-06-2007, 11:44 AM   #21
cycleway4   cycleway4 is offline
i believe what jcwhitney has is custom speedo cable kits
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 03-08-2007, 07:46 PM   #22
FMYStreetRacer   FMYStreetRacer is offline
well the lifan cable is different, but not by much. it is longer. the part that goes into the throttle grip that is the adjuster is 10mm instead of 8mm like the roketa. i took the part that the cable screws into back to work and drilled/taped it out to the same size. then i routed the cable wrong aout 5 times and pretty sure it's still routed wrong but it's late and i'm meeting some friends up at the bike stunts. i'll post pics later.
Roketa DB-07a
HID Headlight
Old 03-09-2007, 08:39 PM   #23
here's some of the pics i took.
i had to drill and tap this part so that the adjuster portion of the cable would go in.
anyone have any idea where this goes? it fell out while i was taking it apart and i have no idea where it came from.
all done
Roketa DB-07a
HID Headlight
Old 03-09-2007, 09:23 PM   #24
ob1   ob1 is offline
Your "unknown" part looks to be an enclosure part that fits on the inner side of where the throttle cable exits the throttle housing and turns 90deg.
Old 03-10-2007, 05:03 PM   #25
thanks i put it in there this morning and adjusted the cable.
Roketa DB-07a
HID Headlight
