Old 03-03-2009, 04:25 AM   #1
czowner   czowner is offline
Alternative larger fuel tank.
In one of my recent browses through flea bays petrol tanks I came across this:
It's a Hyosung RT125 Karion. It looked about right, and it was!
If you're not a welder you could just drill some fresh holes in the rear mount and twist it to about 30' from the horizontal.
The front mounts drop from the stock tank mountings, I welded a pin for the bobbin (a yamaha item), non welders could improvise with a countersunk bolt?
The tank had no tap, and the original Hongdou tap was too long and fouled the cylinder head. The only Chinese tap I could find at the breakers was this short one, so there's been some careful filing to make it fit.
The finished job, total cost £23 ($35).
Without Googling how big do you think the tank is? It's deceptive.
Jonathan.
Old 03-03-2009, 12:18 PM   #2
hunter   hunter is offline
gas tank
does it hold more fuel than the stock tank?because that would be a plus for these lifans,a little more miles per fill up
Old 03-03-2009, 11:02 PM   #3
Dragon   Dragon is offline
Probably 1.7 gal.
Chinabikeless
Old 03-03-2009, 11:31 PM   #4
AZ200cc   AZ200cc is offline
Nice work :!: , I wonder if any of the desert tanks offered could be made to fit now.
<br />2001 Suzuki DR200SE<br />1997 Suzuki RM250 YIKES<br />1995 Yamaha Breeze 125 daughters<br />1991 Honda XR80r Restored<br />maybe a 2003 Yamaha TTR90
Old 03-04-2009, 04:46 AM   #5
Originally Posted by Dragon
Probably 1.7 gal.
Nowere near, it's a decptive 9 litres in total (2.4 US gall) with .75litre reserve. Gets me a whopping 150 miles to the tankful.
Jonathan.
Old 03-04-2009, 10:26 AM   #6
Jonathan.
The only catch is to find these tanks. I don't think too many Hyosung dirt bikes/enduros came to N. America, but perhaps one could order them from Hyosung, which is still here in N. America.
I wonder if the new Hi-Bird 5 gallon tank, or the Shineray 5 gallon tank will fit the majority of these GY-series bikes. That would be something interesting--the gas would last longer than the bike!!
Old 03-05-2009, 10:01 PM   #7
I wonder if the new Hi-Bird 5 gallon tank, or the Shineray 5 gallon tank will fit the majority of these GY-series bikes. That would be something interesting--the gas would last longer than the bike!! [/quote]
I can't see anything bigger fitting very easily (or looking "right"), unless you want to start changing the seat as well. There's not much room along the top frame tube.
Jonathan.
Old 03-05-2009, 10:16 PM   #8
Maybe a tank off a dr, They sit tall but are not very long
