01-14-2009, 07:06 AM | #1 |
alarm systems
My wifes 4 wheeler is blowing main fuse.I would like to bypass the alarm system to troubleshoot.Is it as easy as unpluging and bypassing,or more involved?It is a TaoTao 110 automatic.
Lifan LF200GY-5 |
01-14-2009, 09:58 AM | #2 |
The alarm system can just be unplugged. But it changes the way is operates a little. Once unplugged you can no longer turn off the engine with the ignition switch, you will have to use the kill switch on the handle bar. Also, the remote start feature could start the quad bypassing the brake interlock. Using the ignition and starter button manually you will have to depress the brake before it will crank.
01-14-2009, 12:09 PM | #3 |
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
01-15-2009, 07:47 AM | #4 |
chrism1
The Remote Kill/Alarm System on The TaoTao 110 can be unplugged and the ignition switch should still operate correctly. They where one of the few companies that had a 110cc atv that the Remote Kill/Alarm System was wired in after the ignition switch.
Thanks, Bruce @ Endless Journey Cycles "Phone Calls Only" ~330-274-0098~ Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST. Dealer for: Lifan, Crossrunner ATVs. http://www.endlessjourneycycles.net |
