11-05-2008, 09:20 AM | #1 |
Taillight help
Could anyone tell me where the tail light connects into the main wiring harness. I tried tracing it back, and it seems as though it is in the main bundle of wires inside the headlight. Is this correct?
11-05-2008, 12:37 PM | #2 |
you have to take off the top of the rear mudguard and the connector block is there
well that is on mine anyway
gy 125 gas gas 250 aprillia rs125 (my baby) Now sold to buy my sons xr 125 If it works leave it or better weld it |
11-05-2008, 01:13 PM | #3 |
I already checked all the connections there, and they seem to be fine, the brake light works, just not the running tail light
11-05-2008, 01:25 PM | #4 |
you need a volt meter then to test the connector block to see if there is a live when you turn the lights on
if that does not work then you will have to bridge a wire from the headlight wire down to the rear of the bike
11-05-2008, 02:20 PM | #5 |
thanks, ill try that
11-05-2008, 10:22 PM | #6 |
Is the running light filament busted? :idea:
'91 Yamaha Warrior- stage 2 '83 Honda ATC 70 '08 Yongjiang 125cc mx (Loncin) '08 Yongjiang 150cc atv (Jinlong) |
11-06-2008, 07:10 AM | #7 |
Did you check this connector under the seat?
The brown is the tail lamp lead, and the Yellow/Green is the brake lamp lead. The green is the chassis ground! First do as mentioned by warrior91, and JUST REPLACE the dual filament bulb, because it is quick and easy, and broken firmaments can be elusive to find because they can contact intermittently. Also check the connections in the lamp socket for corrosion, poor workmanship, poor fitment, etc. Hope this helps. Keep us posted, Tigertamer
07 H-D XL883C 06 LF 200GY-5 Yin and Yang CAUTION Obey The Traffic Regulation. Always Wear a Helmet. Don't Ride After Drinking Wine. Before Operation, Read The Owners Manual Carefully. |
11-06-2008, 08:31 AM | #8 |
Try the bulb first.
Allen
11-06-2008, 10:23 AM | #9 |
i tried a new bulb before, it works occasionally so i thought that it was a loose connection
11-06-2008, 11:43 AM | #10 |
Okay. I would trace the wire and check all connections. The pin sometimes come loose in them.
Allen
