#16 |
I hate Easy-outs too! But I use them when needed.
I have snapped them before when I wasn't careful. I must be very lucky to not have them snap every time :twisted: Thanks, Tigertamer
07 H-D XL883C 06 LF 200GY-5 Yin and Yang CAUTION Obey The Traffic Regulation. Always Wear a Helmet. Don't Ride After Drinking Wine. Before Operation, Read The Owners Manual Carefully. |
#17 |
I've worked on several Subaru engines and the exhaust studs break on a regular basis. At least with a Chinabike replacement heads are relatively cheap. Under $100 say.
Wayne Wildfire WF300-SP |
#18 |
torque
Now that I am ready to reinstall head,does anyone now what the bolts should torque to?I should have checked them before i pulled it apart :roll:
Lifan LF200GY-5 |
#19 | |
Re: torque
#20 | |
Re: torque
Here's a link to torque by bolt size; http://dodgeram.org/tech/specs/bolts/M_bolts.html Should get you close. |
#21 |
That's according to the Hayes shop manual for the Honda CG125 which is the pushrod engine that the Chinese cloned into the 125/150/200/250. So you may want to ramp up the torque a bit according to your bike's displacement.
http://www.chinariders.net/gallery2/...2_itemId=10035 http://www.chinariders.net/gallery2/...2_itemId=10041
#22 | |
It seems to be that 35 or 40 ft/lbs would be closer to the truth, depending on the size of the bolt and pitch of the threads. Just sayin'.... |
#23 |
I know a guy that wants to check out the insides of my 163 FML.
I think its the push rod clone.Anywho....He says a higher compression piston, intake port job,more aggressive cam,and carb should yield 25+hp 8) He says if he could get measurements he could get a piston. Has any body tried this????If not maybe someone could measure :P |
#24 | |
Easier/cheaper just to buy a used XR 250 since they have that much hp stock and a much better suspension to boot. |
#25 | |
#26 |
I have found in the past that the easiest way to remove a snapped bolt or stud is to weld an nut to the end if there is enough material left to do so.
#27 | ||
cranking 20 or more HP into these little 125 gearboxes designed for 11hp is askin for trouble...
